Velociti -Rev Counter not working
- Wheelwore
- Car Model: MK1 Velociti 1.6i
Yesterday i pulled the Black Velociti out for a sunday drive and noticed that the rev counter,turn signals,alarm is not working.The oil buzzer light goes chaos as well..
Where do I start looking to rectify the problem
2007 - Velociti 2.0 ABF Black Magic
2008 - Velociti 1.4i Midnight Blue
2002 - Chico 1.4i White - Chicolux
1996 - VR6 2.8 Golf
1996 - VR6 2.8 Golf
Re: Velociti -Speedo not working
There is a plug with wires (3 or 4) that runs on the gearbox. Check if this is connected and that none of the wires are broken. Its sits near to the dust cap by the clutch on top of the box. The one wire related to your speedo.
Oil buzzer is normally the oil pressure sensor by the head (right side of the head) or on the oil filter (wire that runs on top of the oil filter). Check the wire that runs into these two plugs as well.
Current - Audi TT RS
Current - VW Chico 1.4 - Track Toy
Ex - 2013 Toyota GT86 High Spec
EX - Honda Civic Type R Championship Edition
- Psycho8v
- Car Model: Citi Golf
- Membership No: 1881
Oh crap. Bud, please check your two main fuses by the battery, take them out and give 'em a good clean.Wheelwore wrote:Yesterday i pulled the Black Velociti out for a sunday drive and noticed that the Speedo,turn signals,alarm is not working.The oil buzzer light goes chaos as well..
- Car Model: Polo 1.2 TSI
Or take the battery out to reset
Current: 1.2 Polo TSI 66KW
EX Polo Vivo Blueline
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- Psycho8v
No, it's one of those fuses, I'm pretty sure about it. If the one stuffs around, the engine just dies or refuses to start. When the other one stuffs around, it does the above.Little D wrote:Or take the battery out to reset
- Wheelwore
Thanks will check them after work and provide feedback
1996 - VR6 2.8 Golf
1996 - VR6 2.8 Golf
Oil buzzer also comes on if there is oil pressure but no rpm on the clock. Yeah try disconnecting the battery and see if the cluster will reset.
- Wheelwore
prob is I have 3 batteries all connected to each other in the vehicle. If I disconnect the front the back 2 is still providing power..In order to disconnect power Ill have to disconnect the back batts which is a mission and a half
1996 - VR6 2.8 Golf
1996 - VR6 2.8 Golf
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
3 batteries for what?
I have heard of the same problem this weekend on a 6n polo. The lady in my complex asked me if I could help. So the speedo does not work but the odometer is still turning, could that be a problem with the speedo on the cluster itself? I assumed the speedo pickup would be broken but if the km's are still climbing then i assumed the cluster is the issue.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- Delokes
- Car Make: Vw , Bmw
- Car Model: Mk1 CTi Turbo , 318ti
SOUND!!!VWicked wrote:3 batteries for what?
- VWicked
anyway off topic but Fok, I have had and seen "Sound" in my day but never needed more than one battery a huge alternator and a good capacitor but this car probably pushes over 150db then as I used to push over 140db time and again without issues...
- Delokes
Well then find the fuse for the cluster and pull that.
- Wheelwore
panic-mechanic wrote:Well then find the fuse for the cluster and pull that.
Thanks Will do
1996 - VR6 2.8 Golf
1996 - VR6 2.8 Golf
- Car Make: Jaguar
- Car Model: X-Type 2.2D
Not quite the same issue. In the lady's case it's dry solder joints on the cluster. I take it the rev counter doesn't work either, but the fuel and temperature gauges, indicator and warning lights still work.VWicked wrote:I have heard of the same problem this weekend on a 6n polo. The lady in my complex asked me if I could help. So the speedo does not work but the odometer is still turning, could that be a problem with the speedo on the cluster itself? I assumed the speedo pickup would be broken but if the km's are still climbing then i assumed the cluster is the issue.
Current: Jaguar X-type 2.2D
Ex: 2000 Citi 1.3
Ex: 2000 Citi 1.3
- VWicked
The rev counter is fine just the speedo...
- Wheelwore
My rev counter aint fine...my speedo is
1996 - VR6 2.8 Golf
1996 - VR6 2.8 Golf
- VWicked
So you posted incorrectly?
- Psycho8v
And when you switch your indicators on it's dead on the cluster, yet if you physically check them outside, they work, right?Wheelwore wrote:My rev counter aint fine...my speedo is
- Wheelwore
VWicked wrote:So you posted incorrectly?
fixed
1996 - VR6 2.8 Golf
1996 - VR6 2.8 Golf
- Wheelwore
uuhm correct on the cluster its dead....outside they workPsycho1400 wrote:And when you switch your indicators on it's dead on the cluster, yet if you physically check them outside, they work, right?Wheelwore wrote:My rev counter aint fine...my speedo is
1996 - VR6 2.8 Golf
1996 - VR6 2.8 Golf
- Psycho8v
Re: Velociti -Rev Counter not working
Mine did the same. Was one of the fuses next to the battery. I didn't even have to take mine out, I just wiggled them abit, and checked the cluster. Bob she is your tannie.Wheelwore wrote:uuhm correct on the cluster its dead....outside they workPsycho1400 wrote:And when you switch your indicators on it's dead on the cluster, yet if you physically check them outside, they work, right?Wheelwore wrote:My rev counter aint fine...my speedo is
- Wheelwore
Ok lemme do that tonight...i will be back
1996 - VR6 2.8 Golf
1996 - VR6 2.8 Golf
- VWicked
yup those fuses are a PIA. My cousins car refused to start once, I called Morne and he said remove them clean them and out back and voila...
- Wheelwore
Ok last night I took out , sanded and replaced the 2 fuses next to the battery...still no joy..
Then I noticed that the hazards and Instrument cluster fuses were blown and had them replaced...
Hazards and cluster now working but Rev counter and central locking still not working
1996 - VR6 2.8 Golf
1996 - VR6 2.8 Golf
