No disrespect bud, but if you lift the throttle plate while it is idling, the car is going to rev up. Leave the car off. And leave the tb on the intake. Take the pipe off, grab a cloth, and spray the carb cleaner on the cloth, if it looks bad, spray the throttle and then wipe up, repeatedly. Then, with one hand opening the throttle plate, use your other hand with the cloth with carb cleaner sprayed on to clean underneath and on top of the throttle plate. Once it is clean, you're done. And by repeatedly wiping all the gunk and carb cleaner off of the throttle body, you will have minimal, if not any, entering your engine.Little D wrote:Nope you dont have to remove it.. Just take off the pipe , While the car idling , raise a bit, spray the carb cleaner and all the dirt will be expelled through the exhaust.. Just use cloth to wipe any excess build up
Please note, please let the engine cool down a bit before working on it. Unless you can move like the lord of the dance, you maybe want a cooler environment to work with.
