heat gauge not reaching halfway
Oshy
Post by Oshy » Mon Apr 16, 2018 4:16 pm
HI guys
recently did a radiator change on my citi 1.4 and put in the recommended G12 coolant but now the heat gauge isnt reaching the halfway point at all the most it goes to is a quarter , and right down on freeway driving .
could it be thermostat stuck open ??
Car Make: VW, VW, Aprilia
Car Model: Mk2, Mk3, Aprilia RSV4
Re: heat gauge not reaching halfway
Post by Jetta2 » Mon Apr 16, 2018 4:55 pm
Thermostat stuck open or not installed.
1989 Mk2 Jetta 2.0 8V-T
2017 Caddy Maxi Crew Bus
2013 Aprilia RSV4 APRC
Oshy
Post by Oshy » Tue Apr 17, 2018 8:47 am
Can this damage the engine ??
Post by Jetta2 » Tue Apr 17, 2018 9:01 am
Mosr definately yes.
Oshy
Post by Oshy » Tue Apr 17, 2018 9:34 am
Okay thanks and when replacing the thermostat does all the coolant get drained out as well ? or is there a way of saving the coolant ?
Oshy
Post by Oshy » Tue Apr 17, 2018 10:22 am
Do you know whether my citi 1.4i takes the 80 degree one or the 87 degree ?
Oshy
Post by Oshy » Thu Apr 19, 2018 9:23 am
Howsit guys i replaced the thermostat the heat gauge went up to halfway the day i replaced it , but the second morning it was doing the same thing heat gauge not coming up .
what else could be the issue ?
PapaJo
Post by PapaJo » Thu Apr 19, 2018 9:28 am
Did you fit the same type and size radiator?
PapaJo
Post by PapaJo » Thu Apr 19, 2018 9:32 am
What is the condition if the temperature sensor? Boil some water and put the sensor in the hot water with wiring still attached and check reading on gauge.
When sympthoms are as described above, is the radiator fan kicking in or any water boiling in water bottle.
Oshy
Post by Oshy » Thu Apr 19, 2018 10:38 am
yes fitted same type radiator and switch from goldwagen , only the thermostat is a motoquip part .
Is the temperature sensor located at the bottom of the radiator ?
PapaJo
Post by PapaJo » Thu Apr 19, 2018 10:56 am
No that is the fan thermo switch.
PapaJo
Post by PapaJo » Thu Apr 19, 2018 10:58 am
Temp sensor with 4 pin plug sits on the housing between no 3 and 4 sparkplugs.
Oshy
Post by Oshy » Thu Apr 19, 2018 11:02 am
oh okay thanks bru , will check it out this afternoon .
