Limp mode on 2013 1.2 tdi Blue Motion
Russzs2rb
Registered for: 2 years 2 months
Post by Russzs2rb »
Hi there, hoping someone has some advice with me on this. The warning on the dash came on and the diagnostics showed an error code (can't find it right now) which lead me to replace the MAP sensor on the air intake. I then cleared the error code. The problem I am having is that I can drive for 5km and then the warning light reappears and the car goes into limp mode again, if I turn the ignition off and wait for it to cool down and then restart, the warning light has disappeared and it is driveable for another 5km,then repeats the same issue. Can anyone offer some advice on how to fix this? Will be most appreciative. Thanks!
aristo92
Car Model: Golf MK7 GTI IS20H
Membership No: 3133
Re: Limp mode on 2013 1.2 tdi Blue Motion
Post by aristo92 »
Howsit bud, I think we been to start with that error code first. Please share it here.
Sent from my SM-N986B using Tapatalk
Regards, Armand.
Rides Thread: viewtopic.php?p=2577126#p2577126
Russzs2rb
Post by Russzs2rb »
Thanks Armand, I will post it as soon as I can tomorrow!
Regards, Russell
Russzs2rb
Post by Russzs2rb »
Okay, got the code it is P2279 and says Intake Air System Leak. All advice appreciated!
aristo92
Membership No: 3133
Post by aristo92 »
Russzs2rb wrote:Okay, got the code it is P2279 and says Intake Air System Leak. All advice appreciated!
Do you hear any hissing noises that points to a boost leak perhaps?
Regards, Armand.
Russzs2rb
Post by Russzs2rb »
Hi Armand, no, none. I'm stumped
aristo92
Membership No: 3133
Post by aristo92 »
Russzs2rb wrote:Hi Armand, no, none. I'm stumped
Where are you based? Suggest you take it to someone for diagnosis
Regards, Armand.
CLN1.6TDI FK
Registered for: 2 years 10 months
Car Make: VW Cross Polo
Car Model: Cross Polo Mk5 1.6 tdi 77Kw
Post by CLN1.6TDI FK »
Hi
Check you N75 valve if it has failed, I had the same problem on my tdi same code P2279. The N75 valve is the "boost control valve" with 3 pipes. 1 pipe is vacuum, 1 is to control the boost and 1 is a vent.
For good measure you can check the vacuum system for leaks as well.
My Rides.
2008 9N3 Cross Polo 1.9 TDi
143kw 175kw :cool: on wheels.
2013 6R1 Cross Polo 1.6 TDi 77kw
1995 Golf 3, 2.0l GTI Exec
1995 Jetta 3, 2.0l Exec
1990 Jetta 2, 1.8l CLX
1979 Golf 1, 1.6l GTS
