Hi All,
I drive a '05 mk5 golf 2.0 Tdi with >500k kms. The engine idles high(just above 1k rpm) few seconds after starting engine, followed by both fans running at high speed. Had to replace both fans due to self-destruction. Found a small vaccum leak on the intermediate air hose pipe after the MAF sensor and the one leading to the turbo. I had the small hole plugged but the high idling and fans running continoulsy problem still persists. Does anyone know if this car has O2 sensors? i'm thinking that might be the problem. any advice will be appreciated.
Lucky
mk5 2.0 TDI-High idling & fans continously running
- RebelGTI
- Car Model: MK5 GTi
Re: mk5 2.0 TDI-High idling & fans continously running
My fan is also always on. I were told its the temp sensor that was faulty, replaced that and guess what the fan was still on... So till today my car's fan is always on.
2007 MK5 GTI
Revo Stage 3
Revo Stage 3
Hi RebelGTI, I forgot to mention that i replaced both temp sensors before my cooling fans packed up. dont know where to go from here.
I would expect that a diagnostic read-out of fault codes and measurement blocks should provide the reason for the continuously running fans.
