Hello there Vw club members!
Are there any 1.6 tdi big turbo conversions on the forum, now with time has passed I’ve saw that these cars gained much more potential, my question is what would be a good turbo to run on these platforms ?
Seen some with nozzles and a gt2060 turbo make 320hp (220kw) which were measured at the wheels, so there is definitely some potential.
Big turbo 1.6 tdis
- Carel040
Re: Big turbo 1.6 tdis
Look at this
Saw this bud, but to be fair there are plenty other ones making around 300hp and haven’t broken there’s also a dark side golf also with the same engine and runs a gtb1752, i believe that the rods can handle 500nm max.
Here’s one I believe it’s in turkey with a gt2060 and nozzles
https://youtu.be/uuk7IuvY7bY
- saxo
You will probably need a gtb22 to get that power, and I'm guessing upgraded injector's but you get some happy at the wheel dyno's
That’s true, I’m hoping over 165wkw should be fine aslong as the torque is capped at 480nm
