Unusal turbo flutter/bad lag/loss of power
- Car Model: Vivo GT
Howsit guys. I have some issues on my polo 1.9tdi asz
I dont know what the sound is. Im going to refer to it as "flutter"
About a day ago. When i release accelerator, i hear the the sound of the turbo flutter. Which never used to happen on my tdi.
It lags bad when pushing down hard on the accelerator.
Driving it normal it seems fine. No issues, other than the light flutter sound.
Please help with any ideas on where i should start.
2000 E46 325CI
1997 Toyota Corolla Rsi
2007 1.9TDi
2013 VW POLO VIVO GT
1995 E36 M3 German spec
1991 TOYOTA COROLLA 1.6GL
1990 BMW E30 325i CABRIOLET
1989 FIAT UNO TURBO
1979 FORD ESCORT 1600 SPORT
2007 1.9TDi
1989 FIAT UNO TURBO
- aristo92
- Membership No: 3133
Re: Unusal turbo flutter/bad lag/loss of power
Morning bud, do you have a stock turbo and intercooler?
Sent from my SM-N986B using Tapatalk
Hi. Yes i do.
Stock cooler
Bv39 turbo. (chinese core)
Rk motion file
Stock cooler
Rk motion file
Last edited by NiKHiL_POWER_GT on Tue May 25, 2021 8:32 am, edited 1 time in total.
2000 E46 325CI
2007 1.9TDi
1989 FIAT UNO TURBO
2007 1.9TDi
1989 FIAT UNO TURBO
Could be clogged vanes or turbo leak on the exhaust side.
Ok cool. Something i need to check out. It seems to be running fine this morning. No tsuuu sound. Lol. But will have to look into it. Thank you for your response.
2000 E46 325CI
2007 1.9TDi
1989 FIAT UNO TURBO
2007 1.9TDi
1989 FIAT UNO TURBO
If you go under, you should see black soot marks where the leak is, on the turbo and downpipe.
- aristo92
Maybe also have a look at all your boost pipes as well just for safety sake.
- PoloRolo
- Car Model: Golf 7.5 R-Line
Would also suggest checking your hoses and clamps are tight for boost and intercooling pipes.
Is it safe for me to drive until the weekend?
2000 E46 325CI
2007 1.9TDi
1989 FIAT UNO TURBO
2007 1.9TDi
1989 FIAT UNO TURBO
Without checking we can't say. Turbo might be on its way out, you might be having a boost leak where it's sucking in air/dirt. Find the issue first then you can check if it is safe.
Thank you Callum. Will probably park her off this afternoon. Get her checked up this weekend
2000 E46 325CI
2007 1.9TDi
1989 FIAT UNO TURBO
2007 1.9TDi
1989 FIAT UNO TURBO
Before parking the car off today. Pushed it a little hard once as i was 2 roads away from home.
Definitely lost its power at acceleration.
Then it just slowed down. Acceleration died off. Felt like it was in "limp mode"
Heard a funny dry turbine spool sound.
I stopped and took off again. It feels like it has life in 1st gear and then power fades away ans it doesnt come into boost as normal.
Thank tou Callum. Aristo and polorolo.
Will start off by checking what you guys have suggested.
Car is parked until the weekend.
2000 E46 325CI
2007 1.9TDi
1989 FIAT UNO TURBO
2007 1.9TDi
1989 FIAT UNO TURBO
Please don't drive any longer.
Could be a broken turbo. Hopefully it isn't and can just be rebuilt.
Definitely. Car is parked off.
Also noticed on the valve block. Has those vacuum hoses. The number 3 is not connected to anything. Any idea wer it goes?
2000 E46 325CI
2007 1.9TDi
1989 FIAT UNO TURBO
2007 1.9TDi
1989 FIAT UNO TURBO
Also noticed when i pulled off in first gear. Car normally leaves a cloud of black smoke. This time it didnt.
2000 E46 325CI
2007 1.9TDi
1989 FIAT UNO TURBO
2007 1.9TDi
1989 FIAT UNO TURBO
