Howzit guys, Any help on the PD160’s ,
Car idles around +-900rpm and consumption at that point is around 1.3l/h
I’ve read up online and spoke to couple guys, their PD’s idle around +-700rpm and consumption at that idle is around 0.6, car just had a complete major service and found no faults or errors on it and everything checks out,
Now I’m having problem trying to find out what is wrong, although the car is light on fuel and runs good, it still has an issue and is bugging me, does anyone know what to do,checkup,has had this issue before and resolved it ?
1.9 Tdi Idle and Consumption (PD160)
- Car Make: SEAT
- Car Model: Ibiza Cupra 1.9TDI
Re: 1.9 Tdi Idle and Consumption (PD160)
Pds idle at 903rpm.
High idle consumption is most commonly caused by incorrect timing or a shitty remap.
- Car Make: SEAT
Thanks , car is stock af ... and timing is set correct, so the car does idle around 900rpm from factory ?
Yes. 903rpm from factory
- amstel18
- Car Model: Tiguan Allspace
Be sure the AC is not on, as that also pushes up the idle consumption.
But don't try fix what isn't broke...
Won't hurt checking the injector values with VCDS, as that will tell you if something is really off.
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
