What could be the cause for this ?
The car does not even want to go over 3000 rmp when you press the pedal,
the turbo was repaired so cause cant be the turbo and the glow plugs als new,
Gold 1.9 TDI no power
- Car Model: polo 1.9 TDI
- Membership No: 3340
- chucker02
- Car Model: Citi ADY
Re: Gold 1.9 TDI no power
Was the actuator set correctly after the turbo was repaired? All vacuum lines on? Have you scanned the car yet? Is the engine light on? So many things that needs to be checked before posting what can be the cause
1971 VW beetle
1971 VW beetle
- Cass
- Car Model: Mk4 tdi
actuator or vacuum....the ahf motor is aging and the luk vacuum pump on these need replacing imho , and that could cause a issue
current: vw Golf mk4
1.9 Tdi
1.9 Tdi
Do you have a check engine light?
Any codes when scanned?
vacuum leaks will come up as errors when you scan.
