HI PLEASE I NEED INFO REGARDING REMOVING THE EGR VALVE AND THE CATALISATOR PLEASE IT IS MY FIRST VW
THANKS
2005 TOURAN 1.9 TDI
Re: 2005 TOURAN 1.9 TDI
what info do you need?
- Registered for: 4 years 6 months
HOW TO REMOVE AND BLANK OF THE EGR VALVE , DO I REPLACE THE CATALIST CONVERTER WITH A STRAIGHT PIPE OR JUST BREAK IT OUT AND PUT IT BACK AGAIN
THANKS
THANKS
REMOVE THE PIPE FROM THE EXHAUST MANIFOLD TO EGR HOUSING AND BLANK OFF THE MANIFOLD AND EGR HOUSING PORT WITH EGR BLANKING PLATES. DISCONNECT VACUUM HOSE GOING TO EGR ACTUATOR AND BLOCK IT OFF WITH SOMETHING.
BASH OUT THE CAT OR CUT IT, EITHER WHICH WAY GETS RID OF THE CAT. WHATEVER IS EASIER FOR U.
