So I was at Tyres n More Edenvale. I got good news and bad news.
Good news is my suspension that I just replaced has no issues. A garage in Durban told me I needed shimming on rear suspension. Turns out nothing was wrong.
A quick visual inspection revealed the leak at the turbo. Weird enough the car does not take any oil. Car pulls fine though. Has anyone had anything similar?
Sent from my POT-LX1AF using Tapatalk
How's this leak at the turbo
Re: How's this leak at the turbo
That looks like it's dripping out the turbo inlet pipe?
- Wheel Whore
Will have a look at it this weekend. If so I'm worried how much might be in the intercooler.
- Deranged_9n3
- Darth Vader
- Membership No: 1639
Def looks like the TIP. Remember your motor breathes back into the TIP
My Youtube Channel
Tiguan Track & Field 4Motion
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Loud 'n Low, Rollin' Coal
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
- Thekogm
- Car Make: VW & VW
- Car Model: 95 Polo 1.4i, 03 Transporter
My advice is have the following things checked.
1. Engine blowby, too much blowby might equal worn-out rings.
2. Turbo might be leaking oil into the intake and most of it might get trapped in the intercooler.
or on the phone...
- Wheel Whore
Will have that checked. It's weird because the car doesn't take a drop of oil.Thekogm wrote:My advice is have the following things checked.
- Deranged_9n3
- Darth Vader
To be dead honest with you, remove TIP and clean it. Remove all boostpipes and clean them, including the cooler. Don’t stress it too much, that looks quite normal to me. These motors do have blowby coming out the breather
My Youtube Channel
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
- ED van Greunen
- Car Model: 2003 mk 4 jetta 1.9 tdi
lots of videos around on how to drain your intercooler. I made an oil catch can and only had it on for a trip to Durban and back and was very suprised at how much oil was trapped. it is normal
'Racecar' is 'racecar' spelled backwards
