Good day fellow VW Fanatics, I am new to the forum.
I need some assist urgently and cost effectively, I need the DPF removed from my Golf 6 TDi Bluemotion , software upgrade and a performance chip installed.
I have been shopping around and various workshops charge ridiculous prices.
PLEASE HELP ME WITH YOUR SUGESTIONS
DPF REMOVAL
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
Re: DPF REMOVAL
CPI do a decent file for these 1.6TDI's
Chipping a 1.6tdi is not cheap but neither is replacing a dpf- The reason is due to the fact that the ecu needs to removed from the vehicle and bench flashed, once this is done can the software be loaded via OBD.
Expect to pay around R5500-R6500 for physical removal of the dpf as well sorting out the software side
- Registered for: 3 years 1 month
Re: DPF REMOVAL
Good morning, sorry to steal your thread. I'm having a DPF issue as well. Do you perhaps have contact details for CPI
