Advice needed: FMIC upgrade
Good day VAG people,
I was in the process of upgrading my two side mount intercoolers on my 2007 Audi A4 with a single larger (and more efficient) OEM front mount intercooler when I ran into some hose issues.
I have since found a supplier that has all the bends that I need, which left me with one question: is it worth it?
My biggest concern is that I need approx 2x135° bends and 4x90° bends to retrofit the FMIC. That seems like a veeeery inefficient way to move air. Will that not in itself lead to a significant pressure drop which will just undo the benefit of the less restrictive intercooler?
Keen to hear your thoughts
Sent from my CLT-L09 using Tapatalk
Re: Advice needed: FMIC upgrade
have you actually logged intake temps to see if you think you need it.
No I have not, sounds like a good idea!
What type of logs will be able to tell? Back to back sprints? You prob want to determine at which point heat soak starts to occur? I got a mk 2 Audi TT RS intercooler as a present, so I figured it couldn't hurt treating my tractor with a bit of an upgrade..
The photos show my current setup with the two SMICs and what could possible be with the FMIC.
A decent sized fmic will definitely be more efficient than 2 small side mounts, especially if u have or plan on software.
Another thing is u rather get piping welded up than having too many silicone joiners, u would probably also require a map sensor Flange
- MarshallGTi
- Registered for: 13 years
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
Why not run all 3...?
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
The FMIC is rated for 250kW, I am nowhere near that so having three would we a bit overkill in my opinion.
Is it a daily, is otna drag car? Where is it that you think where you will getbthe advantage. Log that. If you think daily grind in traffic - well lemme tell you no matter which cooler you have on it will make absolutely no difference there.
It's a daily, running software making about 155kW on the crank. There is also minimal traffic where I stay. To be honest this is a case of curiousity. I got the IC - might as well use it. In my mind there is less piping to route from the one SMIC to the next and the FMIC is less restrictive so there should be a benefit associated with the upgrade. But that's an opinion, would love to get other views as well
My view of it is sell the cooler and buy beers with that.
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
The gains in your application moving from twin SMIC to single FMIC are not worth the money/time. I think you will find the intake temps with the twin SMIC are perfectly acceptable for a mildly tuned car.
- dcmk4
- Car Model: MK7 GTi
If the side mount coolers aren't leaking or giving any trouble I would have to agree with the general consensus, it's not worth the trouble or work to change them as they should be more than sufficient to support the car in its current state.
I really appreciate the feedback guys, thanks for taking part in the discussion!
- THANAS
- Forum Advertiser
I think you need a twin FMIC.
Now we getting somewhere
