2015 Golf 7 2.0TDi Highline DSG - Everything failed
HI Guys,
Long story here, but I've blown my mk7 turbo 4 weeks ago, high milage vehicle 183,000km.
The turbo was replaced, and car running perfectly... no issues.
For safety and engine longevity I had the DPF gutted, as I was sure it had something to do with the turbo going.. getting full and/ or blocked.
Myan from CPI did the software DPF delete, and a stage 1 tune for performance.
The same chaps that put the new turbo in, I got them to remove the DPF and gut it, and put everything back.
After putting everything back I got some seriously strange error lights... and power steering failure.
https://ibb.co/B3mdk01
https://ibb.co/mJNvCGz
After trying to clear them a few times, it worked and the car was running perfect, no issues...
Then yesterday I was driving and all of a sudden all of the above errors came back, and I had power steering failure through a corner... very scary stuff.
No when running the VCDS and trying to clear the faults they all just come back.
Any ideas here?
Battery SOC reads 80%
Below is an extract from the VCDS:
Sunday,16,June,2019,09:39:46:16861
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.0.6 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVWZZZAUZ License Plate:
Mileage: 183778km-114194mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 42 44 52 55 5F
VIN: WVWZZZAUZ Mileage: 183778km-114194miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 0100
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC X22 8127
Revision: 83X22---
Coding: 011D0012032505082000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01104L906021DT 002008
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AF0125CFD9E849FDB-802E
4 Faults Found:
17158 - Databus
U1123 00 [047] - Received Error Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 5
Mileage: 183778 km
Date: 2019.06.15
Time: 10:20:55
Engine speed: 1569.00 /min
Normed load value: 0.0 %
Vehicle speed: 34 km/h
Coolant temperature: 99 ∞C
Intake air temperature: 108 ∞C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.480 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: -1.154 m/s≤
19206 - EGR System
P0401 00 [096] - Insufficient Flow
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 183615 km
Date: 2019.06.14
Time: 07:32:58
Engine speed: 1866.00 /min
Normed load value: 48.2 %
Vehicle speed: 95 km/h
Coolant temperature: 73 ∞C
Intake air temperature: 78 ∞C
Ambient air pressure: 1030 mbar
Voltage terminal 30: 14.360 V
Unlearning counter according OBD: 37
Exhaust recirculation valve 1 bank 1: mass flow - nominal value: 0.0 kg/h
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
Exhaust recirculation valve 2 bank 1: mass flow - nominal value: 72.7 kg/h
Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 65.04 %
Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 86.76 %
Air mass at air mass meter 1: 117.2 kg/h
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 2.4023
Engine speed: 0.00 /min
Vehicle speed: 0 km/h
Coolant temperature: -40 ∞C
Intake air temperature: -40 ∞C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
17273 - No Communications with Power Steering Control Module
U0131 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 183778 km
Date: 2019.06.15
Time: 10:20:56
Engine speed: 1278.00 /min
Vehicle speed: 28 km/h
Intake air temperature: 107 ∞C
Voltage terminal 30: 14.460 V
Limitation: accelerator pedal: 0.0 Nm
CAN status - engine control module-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 2
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 2
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 183778 km
Date: 2019.06.15
Time: 10:20:55
Engine speed: 1570.00 /min
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 041 P HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4507
Revision: 05853104 Serial number: TFK01504070900
Coding: 0014
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 254A112024A0DB67C6-8070
1 Fault Found:
21223 - No Communications with Power Steering Control Module
U0131 00 [011] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Mileage: 183778 km
Date: 2019.06.15
Time: 10:20:55
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Component: ESC H42 0610
Revision: 00000000 Serial number: 61015000006005
Coding: 01FA8AA1242309720780060841C72980512490E0608294F300620038C202
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 4894B894F3F2260F1D-801C
7 Faults Found:
0166 - Steering angle sensor
B1168 31 [137] - No Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:15
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 230
Mileage: 183542 km
Date: 2019.06.11
Time: 03:13:59
8238 - Databus
U1121 00 [137] - Missing Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 03:13:59
8242 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 03:13:59
16412 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:25
16413 - Display for Tire Pressure Monitoring
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:25
16418 - Display for Tire Pressure Monitoring
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:25
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 AA HW: 5G0 907 426 AA
Component: AC Manuell H02 1001
Revision: 00001K06
Coding: 00120104200100001000000000000000
ASAM Dataset: EV_ACManueBHBVW37X 003019
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 6AD0221C8D3E341F2B-803E
Fresh Air Blower Front:
Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
No fault code found.
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011510702021
Coding: 03001B46C241227B0BA44080B10C07081000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 000460B49B42DE4F95-8054
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150412 042 0551
Serial number: 150416095733
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y15M04D16H06M14S14
Coding: 90A8DD
Sensor For Anti Theft Alarm System:
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150753BLU
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000062205227
3 Faults Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 187
Mileage: 183473 km
Date: 2019.06.06
Time: 15:22:42
555285 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:20
556053 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:20
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391510508427
Coding: 0031051011
ASAM Dataset: EV_EPHVA18AU3700000 002024
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 3D7AD940AC3073A7BE-8068
3 Faults Found:
13637426 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:15
13638913 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:15
13638914 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:15
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R0J2VM$
Coding: 98CCC000000000005C0000CF00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4182A5B0D0C81747DA-8014
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 001 604 15
Component: SideSensor_Df 001 0887
Serial number: 35767000000025B0A31H
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 001 604 15
Component: SideSensor_Pf 001 0887
Serial number: 3586700000012C31141B
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 401 304 15
Component: SideSensor_Dr 001 6149
Serial number: 3516502BD1A14CA2709G
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 401 304 15
Component: SideSensor_Pr 001 6149
Serial number: 3526502C31A8785182DF
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 401 404 15
Component: FrontSensor_D 001 6149
Serial number: 3556502991A87861A06F
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150410400729
Coding: 0410
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F86A348A63C61B7AC-806A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 741 HW: 5G1 920 741
Component: KOMBI 203 5297
Coding: 27A419082B80000800082A001400000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009003
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 64CC4C246F1A626F11-8030
1 Fault Found:
16776978 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:14
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW MQB High 128 1204
Revision: -------- Serial number: 0003384659
Coding: 030100040F087300EF00004A1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 72E03A7CA5EEFCDF93-8026
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0038
Serial number: 29150000733600095155
Coding: 29FFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 0047236403
2 Faults Found:
131602 - Power Steering Control Module
U101D 00 [009] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 17:14:53
Supply voltage: Terminal 30: 12.3 V
Terminal 15: OFF
65794 - Data Bus for Suspension
U10AE 00 [009] - 1-Wire Mode
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 235
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:18
Supply voltage: Terminal 30: 11.5 V
Terminal 15: On
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511
Component: FLA H04 0002
Revision: AA001001
Coding: 02028864727264565625393E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B5EE7184244ED1710-807E
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 300315BCT20903
Coding: 003A02208001040000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 4280AABCD5CE0C5FC3-8016
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000005926261
Coding: 0D0000
1 Fault Found:
65588 - Motor for Window Regulator
B1487 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 232
Mileage: 183718 km
Date: 2019.06.14
Time: 12:30:03
Address 44: Steering Assist
Cannot be reached
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 290315BCR20153
Coding: 003A00208E01040000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000005969633
Coding: 150000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 230
Mileage: 183542 km
Date: 2019.06.11
Time: 00:28:34
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 029E00000B000200
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
VCID: 4084A0B4DBC21E4FD5-8014
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
1 Fault Found:
13705474 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:20
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 819 A HW: 5G0 035 819 A
Component: MU-S--ER 041 0421
Serial number: V1C01704151061
Coding: 02730000FF00000011110001000900001F0100860100010001
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 27561B285EACC977F4-8072
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H60 0030
Serial number: VWZ8Z9RS208NAD
End-------------------------(Elapsed Time: 03:56)--------------------------
Any ideas here?
www.Ross-Tech.com
Revision: 83X22---
4 Faults Found:
17158 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Mileage: 183778 km
Date: 2019.06.15
Time: 10:20:55
19206 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 183615 km
Date: 2019.06.14
Time: 07:32:58
U0131 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 183778 km
Date: 2019.06.15
Time: 10:20:56
U0126 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 183778 km
Date: 2019.06.15
Time: 10:20:55
Coding: 0014
1 Fault Found:
U0131 00 [011] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Mileage: 183778 km
Date: 2019.06.15
Time: 10:20:55
7 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 230
Mileage: 183542 km
Date: 2019.06.11
Time: 03:13:59
8238 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 03:13:59
8242 - Databus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 03:13:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:25
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:25
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:25
Revision: 00001K06
Coding: 0E4DDD
Coding: 90A8DD
Alarm horn:
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 187
Mileage: 183473 km
Date: 2019.06.06
Time: 15:22:42
555285 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:20
556053 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:20
Coding: 0031051011
3 Faults Found:
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:15
13638913 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:15
13638914 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:15
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 0410
1 Fault Found:
16776978 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:14
Alternator:
Coding: 29FFFF
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 17:14:53
Terminal 15: OFF
Freeze Frame:
Fault Priority: 2
Reset counter: 235
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:18
Terminal 15: On
Revision: AA001001
Coding: 0D0000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 232
Mileage: 183718 km
Date: 2019.06.14
Time: 12:30:03
Cannot be reached
Coding: 150000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 230
Mileage: 183542 km
Date: 2019.06.11
Time: 00:28:34
Coding: 2E0000
Coding: 2E0000
1 Fault Found:
13705474 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 183542 km
Date: 2019.06.11
Time: 00:06:20
2015 Golf MK7 2.0 TDi Highline. DSG. White
2012 Polo 6R 1.6 TDi Comfortline. Manual. Grey
2011 Polo 6R 1.4 Comfortline. Manual. Black
2005 Polo 9N 1.4 Trendline. Manual. Silver
Re: 2015 Golf 7 2.0TDi Highline DSG - Everything failed
My mk7 Gti battery SOC was showing 80%. Stop-Start stopped working and error code started intermittently popping up regarding e handbrake. Dsg changes seemed to be not so smooth( almost like holding gear a bit too long before chanfing, also intermittent).
Changed battery and sorted.
VW MK7 GTI DSG. White.
MB C200 Avantgarde A. Palladium Silver.
Ex's
2006Mk5 Jetta 2.0 TFSI DSG. Silver
2002Mk4 Gti. Silver
2008 MB C180k Avantgarde A. Silver
2011 6R Polo Gti. Silver.
2005 9N TDI Sportline. White
2001 MK4 GTI. Black. Sunroof.
1996 MK3 GTI. White. S3 wheels.
2000 MK4 2.0 Highline.GTI Wheels.
1991 MK2 GTI. White. (Best car owned ever)
1991 MK1 CTI. White. Momo EVO1's
Ex's
2002Mk4 Gti. Silver
Thanks!jtm wrote:My mk7 Gti battery SOC was showing 80%. Stop-Start stopped working and error code started intermittently popping up regarding e handbrake. Dsg changes seemed to be not so smooth( almost like holding gear a bit too long before chanfing, also intermittent).
So I needed to move the car out of our top garage and park it in the bottom one. The vehicle moved and didn’t have issues engaging reverse and first gear. So I’m hoping the gearbox is fine... steering was obviously a mission with regards to not having the power steering working.
Where on the VW battery does it tell you the age? Manufacture date?
Also VW just quoted me R4600 for a replacement battery. That sounds insane.
- Car Make: Toyota
- Car Model: Corolla D4-D
- Membership No: 2016
You can get the correct Varta units , just Google it and give them the ratings on it , if you in JHB send me the vin will try and better the OEM unit price...Audi had mines cheaper than Varta R3200 Vs R3500 for the diesel spec battery which should be you unit as well.Ac619491 wrote:Thanks!jtm wrote:My mk7 Gti battery SOC was showing 80%. Stop-Start stopped working and error code started intermittently popping up regarding e handbrake. Dsg changes seemed to be not so smooth( almost like holding gear a bit too long before chanfing, also intermittent).
Also VW just quoted me R4600 for a replacement batter. That sounds insane.
2013 A3 1.6 TDi S-Tronic 8V.1
2013 Ford Focus 2.0 Sport
2011 Hyundai i20 1.4
2006 Toyota RunX
2006 Toyota RunX
I don't remember seeing a manufacture date on the vw battery. If you request a printout from VW dealer, it will give you all the details whilst still under motorplan incl when, if, battery was replaced.
VW also has the economy batteries (also has 2 yr warranty) for around R2k. That was for a stop start battery.
If it has a battery monitor control module, You'll need to have the battery coded too when changing. VW wants nearly R1k for the coding. Get someone with VCDS to do this for you. Possibly charge less than half that.
Ex's
2002Mk4 Gti. Silver
Ex's
2002Mk4 Gti. Silver
Thanks. I have a VCDS and cable. Seems like the walk through a are simple enough to code the battery. I’m getting the guy from battery centre to come to the house and test my battery for me.jtm wrote:I don't remember seeing a manufacture date on the vw battery. If you request a printout from VW dealer, it will give you all the details whilst still under motorplan incl when, if, battery was replaced.
Holding fingers it’s the battery and a replacement unit just sorts out all my problems.
All the research I’ve done. Was around battery issues. So I went and bought a new VW battery (R4400 later) and put it in the car. Programmed the new battery serial number and everything using VCDS. The car was golden!!! No error lights all working.
Then as I got to work, I was turning into my parking. I lost power steering and all the fault lights came back again.
What the hell? Has to be power/ electrical? Car was driving without any issues- briefly.
Check earth cables and the fuses on the box in the engine bay.
Thanks. Car is booked in with my mechanic tomorrow. I will ask him to check l this outpanic-mechanic wrote:Check earth cables and the fuses on the box in the engine bay.
I will revert with what happens.
Hi everyone!
So seems for some very bizarre reason, behind the battery (once removed from the vehicle) where I think the battery negative and some other cables run to earth.. it was loose! The actual nut was loose.. my mechanic triple checked and cleaned all other cables. Put the battery and air box back in. Started the car.. and voila!! Car started, steering was normal and all fault codes automatically cleared in a couple seconds.
Seems like when we put the new battery in, because the earthing cables are so close. Tight space. We could have pushed the loose cable on “more” so it made better contact. Then as I drove it, with the vibrations it must have wiggled off and caused the intermittent voltage issues.. immediately causing “limp/safe” mode on a couple of the cars electronics.
Suppose the new battery was a waste of money, however i did replace the original 5 year battery... assume that was a good preemptive move.
Drove 50km no issues so far
Will post a photo of the problematic cable, and location tomorrow.
Super stoked everything is sorted.
Thanks for the help everyone.
hi
Could you please share the picture of loose cable with us, thx
bj
bj
Ac619491 wrote: ↑Thu Jun 20, 2019 10:38 pm Hi everyone!
