Polo 1.6 TDI Electrical Issues
I've been having issues with my Polo 1.6 TDI (2012) lately where the bulb failure light comes on every time I start the car. The rear number plate lights sometimes work and other times they don't. Some of the times the power steering takes a couple of seconds before it works as well.
I recently fitted a new battery 646CE but I am thinking that I should rather have a 652 fitted. I don't know if that could be the issue.
Other than that, the car sometimes struggles to start and other times cranks and starts immediately.
I don't think that there could be any major electrical issues but I am not sure.
Any one else had similar issues?
- Car Model: Polo Tdi
Re: Polo 1.6 TDI Electrical Issues
Check the battery earth cables to body
..inspect fuses on battery for cracks
..starter could need an overall......
Bulb monitoring can be turned off by someone who has vcds .
Thanks smoke.machine
I've checked the earth cable to car, will check the fuses as well.
Think I'll have the starter checked as well. Thanks!
Hi. I’m new to the forum and looking for help with my “97 polo classic. I left her home for a month and when I came back she wouldn’t start. The engine just turns over but no lights on the cluster nor does the fuel pump come or or the throttle valve. Please help
Dublin wrote: ↑Sat Apr 06, 2019 9:31 am Hi. I’m new to the forum and looking for help with my “97 polo classic. I left her home for a month and when I came back she wouldn’t start. The engine just turns over but no lights on the cluster nor does the fuel pump come or or the throttle valve. Please help
- Saiendra
- Criminal Troll.
- Car Model: 2019 Polo Vivo 1.4 C/Line
Please start your own thread however it sounds like the battery fuses have come loose. Check the 2 main fuses on the left side of the battery.Dublin wrote: ↑Sat Apr 06, 2019 9:31 am Hi. I’m new to the forum and looking for help with my “97 polo classic. I left her home for a month and when I came back she wouldn’t start. The engine just turns over but no lights on the cluster nor does the fuel pump come or or the throttle valve. Please help
Daily - Limestone Grey 2019 Volkswagen Polo Vivo 1.4 Comfortline.
So I've checked the earth cables and they seem to be fine.
The car has recently started to crank for a long time now too, it seems to start on the 2nd try when the engine is cold which is why I suspected the battery initially.
I had the same problem on a previous diesel car (Hyundai Getz) and it turned out to be dirty injectors.
Thing is, I only fill up with 50ppm or 10ppm whenever I am at a Sasol fuelling station?
So after taking the car to my good friends at Bosch - it turned out to be the battery
I had a 646CE battery in the car. I bought it from the 2nd hand dealer like that because they read somewhere that the 646CE is used in all models. What they failed to see is that it is the correct battery for all petrol models - the diesel models all use 652's. This seemed to have solved all my issues. I still have a loose connection though as my rear number plate lights sometimes do not work after starting the car.
