VW T5 KOMBI 4TH GEAR
- Registered for: 5 years
Hi there
I am looking for gear 4 of the VW T5 Kombi or transporter. Its a 1.9 TDI 2009 model. I have looked all over JHB CBD area and most gearbox shops do not have the part. I cannot afford to buy another gearbox hence I need the part only.
Any suggestions or places I can look or anyone has the spare to sell to me?
Regards
Sechaba
Regards
Sechaba
- Stefan0909
- Car Model: Tiguan 2.0TDI
Re: VW T5 KOMBI 4TH GEAR
Call Paul from Mr Gearbox 016 981 2826 and speak to him
1.4i Velocity Stock
1.4i Kia Rio Stock
1.8i VTEC Honda FRV Stock
Citroen DS3 Techno Pack Stock
1.4i Velocity Stock
1.4i Kia Rio Stock
Thank you Stefan, done. He will check and get back to me. Appreciate your help.
Hi Guys
Still no luck in finding the 4th gear for the VW Kombi/transporter. Any one have any idea where I can get this?
Hi Guys
Have you tied erlemanns in jhb?
yes sir I have tried Erlemanns. I also tried Delport. They dont have it.
Agents?.
Agents are bloody expensive
Managed to get the 4th gear but the teeth are a bit more. Original out of the box gas 27/33 and 32 teeth. The new 2nd hand one has 32/33 and 31 teeth. Is this not going to give me issues?
I think these Kombi are a problem. Nice to drive but troublesome.
don't think it will be an issue no very small ratio change
Ta panic. Will feedback once it's put together.
Good day all, what is the best gearbox oil to use for a diesel car, vw T5 Kombi and what is the best oil to use for high mileage diesel car?
Regards
Regards
use the spec quoted in the manual for the gearbox oil. being diesel has nothing to do with it,
I like liqui moly 4200 for those engines.
Hi Guys
I have just finished with the gearbox, after a week of driving the car is now taking out white smoke while driving or accelerating.
Turbo has been done, new head was put in, I dont know what else to do.
Any advise on what might be the issue now?
- Membership No: 1893
5L petrtol and a box of matches?
Ex's:
'07 VW Golf MK5 GT - SOLD
Ex's:
- Car Model: Polo 1.6 TDI
I don't know much about cars but i had a diesel bakkie having white smoke and the problem was that the diesel was contaminated. Another time the diesel filter was clogged and after a sometime the injectors had to be fixed. Hope this helps.
Sent from my G3312 using Tapatalk
Since the head was done, was the injector seals replaced? New bolts used?
T5 1.9 has an AXB engine, pretty much the same as the polos and seats. Same stuff apply, lots of info regarding Injectors and seals on here
The seal was changed after the head was done, injector were checked and tested. I will try the filter and change oil to see if there is any change.
