I have a T4 2,5 TDI Caravelle and loosing water but cannot see any leaks.
sometimes i smell anti freeze but no water on carpets and heat gauge normal.
can it be the water reservoirs cap?
Oil is normal.
how do i bleed the water system?
T4 2,5 TDI Caravelle loosing water
- Membership No: 2033
Re: T4 2,5 TDI Caravelle loosing water
Do these things have heater core's for the heater function, perhaps it is leaking?
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
THE HEATER COILS IS USUALLY INSIDE THE CAR UNDER THE DASH .
CARPETS IS DRY SMELL ANTI FREEZE ONLY WHEN DRIVING
SOME TIMES THERE IS A VAPER SMOKE LIKE FUME BLOWING THREW THE AIR VENTS
WITH AIRCON ON FIRST TIME I SAW IT THOUGH THE DASH WAS ON FIRE
AIRCON WORKS WELL
AIRCON WORKS WELL
They often start leaking in the egr cooler. So the water gets burned in the exhaust system. So you smell it but don't see it.
