Hi,please can someone tell me the function of a vacuum distributor valve on a 2008 jetta 1.9 tdi?mine is leaking as per VW,what will this affect on my car while this part is leaking?
Vacuum distributor valve
- Mr.G24
- Car Model: MK5 Jetta 1.9 TDi Comfortline
2008 VW Jetta 1.9 TDI Comfortline (Reflex silver)
77kw @ 4000
250nm @ 1900
77kw @ 4000
250nm @ 1900
Re: Vacuum distributor valve
The main purpose of it is that it controls the turbo, egr and asv.
It it's leaking, chances are it wont be operating those 3 components properly..
- Mr.G24
Okay,so will it make my car heavier on diesel usage and lack of power etc while leaking?this is what im experiencing at this stage.
77kw @ 4000
250nm @ 1900
77kw @ 4000
250nm @ 1900
Probably. If it doesnt have enough vacuum to operate the turbos vnt mechanism then u will have boost issues..
U rather check on ur own, if u have any damaged vacuum pipes or if the vacuum reservoir is leaking..
