1.9tdi bxe going crazy
Hi guys big problem with a jetta 5 tdi, so after a day of heavy rain I went out to move my car and it started fine and all of a sudden oil pressure warning comes on and I shut down car start car again no oil light but power steering, traction control,handbrake lights stay on and car idles for a moment and shuts down on its own and also when ignition is switched on radiator fan runs
Re: 1.9tdi bxe going crazy
You got water into a control module. Make sure your rain tray drains are open and start a search of where control modules are situated and see if you have carpets that are wet which will indicate water coming into the car.
- Membership No: 1268
What panic said
i had similar symptoms on my jetta
water got into the canbus gateway control unit
2014 Jetta 6 1.4TSI Comfortline
2011 Mercedes C180 CGI Avantgarde Silver
EX
2005 Velociti 1.4i Black Magic
83.6KW 186.4NM @ RBTS
http://www.vwclub.co.za/forum/viewtopic ... 11&t=64053
2007 Jetta 1.9TDI Candy White
http://www.vwclub.co.za/forum/viewtopic ... 1&t=145040
EX
ok thanks guys where are these modules in engine bay or inside car and how do they look any info and pics will help me alot
they are both in the rain tray and inside the car. USe google. search for control module location jetta 5 and see what yo can find. I also don't know all of them and find it that way.
Look for SSP's for that car.
thanks panic
ok gateway controller got water damaged causing ecu to short also and R9500 later car is running again
- Membership No: 2033
Any reason found to have caused the water damage ?
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Almost always the same reason. Stuff like leaves etc blocking the rain tray drain.
Yip, but are these things not then somewhat water resistant (seeing that they might be exposed to moisture)?panic-mechanic wrote: ↑Tue Jul 31, 2018 9:03 am Almost always the same reason. Stuff like leaves etc blocking the rain tray drain.
HOWIE-WP,
Resistant being the word. Ie splash proof, not water tight as in dive proof. Ie If you submerge the thing in water it will get in.
OK, makes sense then.panic-mechanic wrote: ↑Tue Jul 31, 2018 12:21 pm Resistant being the word. Ie splash proof, not water tight as in dive proof. Ie If you submerge the thing in water it will get in.
HOWIE-WP,
