Engine overheat
Engine overheat
Hi Guys, I drive mk5 1.9 tdi and experience problem when driving over 120km/h but I should stop to buy something while the engine is still in idling mode, the overheat taker longer to occur despite been a bit above 120km/h.
Can be assisted
Can be assisted
Re: Engine overheat
thermostat, im guessing...
2001 'rolla 160 gle (ex)
2005 old schooled caddy (ex)
1995 vw golf 1 ((ex)
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
Re: Engine overheat
It looks like english...
- Car Make: VW, Toyota
- Car Model: 1.8 Caddy; Yaris T3 Spirit
- Scatman
- General
- Car Make: BMW
- Car Model: 320d Msport
- Membership No: 1773
Re: Engine overheat
Not really sure what's going on, but I'm guessing your thermostat is stuffed. May even be your waterpump failing. Could be your radiator fan module/motor that's failed. Does it overheat if you have your aircon on? Do your fans spin slowly when you idle the car and switch the aircon on?
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Membership No: 2033
Re: Engine overheat
Wat????Tabiso wrote: ↑Wed May 02, 2018 4:31 am Hi Guys, I drive mk5 1.9 tdi and experience problem when driving over 120km/h but I should stop to buy something while the engine is still in idling mode, the overheat taker longer to occur despite been a bit above 120km/h.
Can be assisted
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Re: Engine overheat
Apologies Guys for the message send earlier but THANKS to those who did not short circuit their brain by managing to make sense from what has been written and provided assistance.
Re: Engine overheat
I recently went out of aurcon and must refill it soon. So, overheating in that regard, I cannot really tell. Coming to the fan spinning slowly, no it appears to be normal. Have tried to observe that.Scatman wrote:Not really sure what's going on, but I'm guessing your thermostat is stuffed. May even be your waterpump failing. Could be your radiator fan module/motor that's failed. Does it overheat if you have your aircon on? Do your fans spin slowly when you idle the car and switch the aircon on?
Re: Engine overheat
Tabiso wrote:I recently went out of aircon gas and must refill it soon. So, overheating in that regard, I cannot really tell. Coming to the fan spinning slowly, no it appears to be normal. Have tried to observe that.Scatman wrote:Not really sure what's going on, but I'm guessing your thermostat is stuffed. May even be your waterpump failing. Could be your radiator fan module/motor that's failed. Does it overheat if you have your aircon on? Do your fans spin slowly when you idle the car and switch the aircon on?
Re: Engine overheat
Tabiso wrote: ↑Thu May 03, 2018 12:24 amI recently went out of aurcon and must refill it soon. So, overheating in that regard, I cannot really tell. Coming to the fan spinning slowly, no it appears to be normal. Have tried to observe that.Scatman wrote:Not really sure what's going on, but I'm guessing your thermostat is stuffed. May even be your waterpump failing. Could be your radiator fan module/motor that's failed. Does it overheat if you have your aircon on? Do your fans spin slowly when you idle the car and switch the aircon on?
The short circuit in my brain caused an assumption that the "aurcon" escaped from your head and I can only recommend that you refil that as soon as possible, before observing anything again... please!
If the thing (your car) is overheating, check thermostat and waterpump first, feel the top and bottom pipes going to the radiator and report back...
- Registered for: 8 years
Re: Engine overheat
Tabiso,
I presume with "overheat" you are referring to the radiator fan switching on. This is NOT overheating, but is a normal operation for regulating the coolant temperature.
TDIs tend to generate less heat than petrol models, especially at idle, because the combustion is more efficient. If the fan takes a long time to switch on, I wouldn't worry about this, especially if the coolant temperature is at 90 when you're driving on the highway. If it's below 90, then your thermostat is faulty and should be replaced.
Re: Engine overheat
my head hurts.
