Guys,
Where can I get a seal kit? Need to do this very soon. Pump is leaking and I'm starting to loose power now too, think it's probably sucking air or loosing pressure, sometimes ideling high also.
Can't seem to find the seal/repair/rebuild kit anywhere!
Golf 4 tdi leaking diesel pump
- Car Model: MK4 TDI
1.4i citi Golf 2000.
1.9TDI Golf 4 2001.
vag-com user.
1.9TDI Golf 4 2001.
vag-com user.
Re: Golf 4 tdi leaking diesel pump
only VW themselves for the kit or try Bosch(diesel electric)
DO NOT try this trick of doing it in the car as some videos advise. take the pump off and do it upright in a bench. If you get it even remotely wrong while it is in the car you WILL end up breaking the pump shaft - ask a few members here.
Oh no!... Was really hoping to do the job whithout removing it from the car...
1.9TDI Golf 4 2001.
vag-com user.
1.9TDI Golf 4 2001.
vag-com user.
