Golf 5 2.0 TDI Sportline DSG service
DJ7
Car Model: MK5 2.0 TDI DSG
Membership No: 3238
Post by DJ7 »
Hi All,
My Golf is due for the 255 000km service. Going to take it away to have it done, but was just wondering, what is supposed to be replaced at this service interval. Just so that I am a bit more clued up when taking it away and don't get "hit over the head". This is my first diesel car, so don't want to go around scratching on it just yet.
Also, if people have a recommendation for a very good oil then that would also be welcomed.
Any help would be appreciated.
Ex: '97 Astra Estate 200i
'00 Corsa 200 GSI 16v
'96 Astra 200i E 16v
'02 Corsa 160 GSI
'93 Ballade 160e
'95 Astra 200i E 16v
8VALVE-zn
Car Make: VW Golf 1
Car Model: 2.0 h8 valve
Re: Golf 5 2.0 TDI Sportline DSG service
Post by 8VALVE-zn »
First thing to do is maybe call VW and get a history update on the car- a good starting point before spending money you don't have to.
Cambelt needs to be done if not done
Water pump needs to be done if not done with the cambelt
VW spec oil (505 or 507 spec)
Rudi46
Registered for: 14 years 6 months
Car Make: Nike
Car Model: Walk and see more
Post by Rudi46 »
DJ7 wrote:Hi All,
Hi DJ7
When last was the cambelt and DSG Service done. Cambelt is every 120k km and DSG is every 60k km . I would say if these where not done on 240k km and you dont know if they have beed done in the last 60k km you should do both.
Major engine service Which Included
Engine Oil-(VW 505.01 Spec oil for PD Engines) Shell helix HX7 AV, they come in 1Lt's only. R95 a L at goldwagen Require 5L
Engine Oil Filter - R82 at Goldwagen
Air Filter - R145 at Goldwagen
Diesel Filter - R240 at Goldwagen
Pollen Filter - R125 at Goldwagen
Cambelt with Waterpump and all Rollers. R3024 at Goldwagen
Coolant Change. Price need to check for you
Gearbox Service
DSG oil Filter - R267 At Goldwagen
DSG oil - R233 per Lt at Goldwagen Require 6L
I would also Sugest a Brakefluid change. And then just a good checkup on all other Items like brakepads, Engine mounts Ect.
Prices provided is what I paid last week for my Service, I have done all work myself. So would not know what the labour cost would be.
I hope this helps you.
Cheers
Rudi
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
DJ7
Membership No: 3238
Post by DJ7 »
8VALVE-zn wrote:First thing to do is maybe call VW and get a history update on the car- a good starting point before spending money you don't have to.
Car has full service history.
This is the first service I will have to have done since taking ownership of the car.
'02 Corsa 160 GSI
'93 Ballade 160e
DJ7
Membership No: 3238
Post by DJ7 »
Rudi46 wrote:
DJ7 wrote:Hi All,
Hi DJ7
Gearbox Service
Cheers
Rudi
Thanks so much for the useful info. Turbo was reconditioned, head was done over, waterpump and cambelt with rollers was also done then.
So, looks like I am doing normal service, dsg service and coolant and check the rest of the car out.
'02 Corsa 160 GSI
'93 Ballade 160e
Rudi46
Car Make: Nike
Post by Rudi46 »
DJ7 wrote:
Rudi46 wrote:
DJ7 wrote:Hi All,
Hi DJ7
Gearbox Service
Cheers
Rudi
No problem, I would also skip the coolant as they should have done that with the cambelt service. Unless you see that its not lekker anymore.
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 01 Golf 4 Tdi
DJ7
Membership No: 3238
Post by DJ7 »
Coolant seems good still. Would had to have been done at the 240k service.
'02 Corsa 160 GSI
'93 Ballade 160e
DJ7
Membership No: 3238
Post by DJ7 »
Seems, like it is almost that time for me again.
So, it is almost 270 000km service time. The DSG service needs to be done this time and already have the filter and oil.
So, this service, is it just:
Engine oil
Engine oil filter
Air filter (Cleaned as it tis K&N)
Diesel filter
Is that it or am I missing anything?
'02 Corsa 160 GSI
'93 Ballade 160e
Howie-WP
Membership No: 2033
Post by Howie-WP »
DJ7 wrote: Fri Oct 12, 2018 2:41 pm Is that it or am I missing anything?
Brake pads and disks? When last were they changed. Otherwise good, check service book if 270k km is just oil service, then you good. :driving:
ICE King
Post by ICE King »
Brake Fluid? should be done every two years.
Registered for: 13 years
Car Make: Fiat, Toyota, Mazda
Car Model: Uno, Auris, CX-5
Post by Unobeat »
DJ7 wrote: Fri Oct 12, 2018 2:41 pm Seems, like it is almost that time for me again.
Engine oil
Engine oil filter
Diesel filter
I am very impressed with the kilos covered.
How is the car though treating you so far even though you have owned her for over 20K kilos.
Cabin filter?
DJ7
Membership No: 3238
Post by DJ7 »
Howie-WP wrote: Fri Oct 12, 2018 2:53 pm
They were checked last service and were still good and will check them again this one. :thumbup:
'02 Corsa 160 GSI
'93 Ballade 160e
DJ7
Membership No: 3238
Post by DJ7 »
ICE King wrote: Fri Oct 12, 2018 3:01 pm Brake Fluid? should be done every two years.
Thanks. :thumbup:
'02 Corsa 160 GSI
'93 Ballade 160e
DJ7
Membership No: 3238
Post by DJ7 »
Unobeat wrote: Fri Oct 12, 2018 3:53 pm
Engine oil
Engine oil filter
Diesel filter
Cannot fault her at all hey. Only replaced the coolant bottle besides services. Drives really well as well. Guess I can be lucky coz of the maintenance done by the previous owner.
'02 Corsa 160 GSI
'93 Ballade 160e
DJ7
Membership No: 3238
Post by DJ7 »
panic-mechanic wrote: Tue Oct 16, 2018 8:20 am Cabin filter?
Replaced last service. Is it advisable to do it every service? If so, then I will add it to the list.
'02 Corsa 160 GSI
'93 Ballade 160e
I guess it depends on how much dust is in your area. Here we change them every service.
DJ7
Membership No: 3238
Post by DJ7 »
panic-mechanic wrote: Fri Oct 19, 2018 11:10 am I guess it depends on how much dust is in your area. Here we change them every service.
I only drive 2 weeks a month to work, but there is roadworks, so probably a good idea to replace it then. Coz just based on how dirty the outside gets from the dust created by the roadworks, I am sure the cabin filter would be filthy.
'02 Corsa 160 GSI
'93 Ballade 160e
