Polo 1.4 TDI PD White Smoke
- Henry@AMF
- Car Model: Polo 1.4 TDI
Hi All,
I am new to forum. I am hoping I could get some help with my car and I will list what I have done.
(Cambelt broke)
1. Replaced valves, valve guides, valve stem seals and lifters
2. New head gasket from GW
3. Replaced head bolts and torqued to spec
4. Set timing and cam timing
What I have not done.
1. Set cam timing on VCDS
2. Not sure if workshop replaced seals on injectors and if they were removed but I'm guessing they where.
What I'm experiencing now.
1. Exhaust smokes white smoke when revving or accelerating.
2. I looked in water reservoir and there was really thin layer of oil/ dirt almost like exhaust gasses( could be that I did not flush system properly as oil cap is normal with no white colour )
What could be the problem - Head gasket leaking, Diesel injector settings wrong, diesel leaking past seals?
If any one can give some advice, I would really appreciate it
(Cambelt broke)
- SayedMK1
- Car Model: MK V GTi
Re: Polo 1.4 TDI PD White Smoke
Did you check the oil cooler ?
- Henry@AMF
No to both questions. How would I check the oil cooler?
Bad oil cooler would only be the solution for the thin layer of oil in water, or will it be for the white smoke aswell?
- SayedMK1
You can pressure test it yourself . Remove the unit then block off one end with a hose and plug it . Put another piece of hose on the coolant end ,depending on what air source youll be using youll have to get creative with plumbing it to pump air into the unit . dump it in a bucket of water and pump in air ,if you have a compressor set it on 6/8 psi if not use a bicycle pump , if you see bubbles youll know its cracked meaning the oil is mixing with the water .Henry@AMF wrote:No to both questions. How would I check the oil cooler?
Also check for boost leaks ..
- Henry@AMF
So I have an update.
I saw some bubbles in water and they increase when I rev the car a little higher.
It's safe to say head is not on properly as it's leaking exhaust gas into water and water into one of my cylinders.
Time to strip again.
Any advise from here on? Head is probably not straight...It did not overheat but I have no other reason why head gasket is leaking
White smoke that smells strongly of diesel means injectors that are not working properly.
- Henry@AMF
I'm tired of scratching now. Taking it to Rodac as I don't have the time to fix it.
As for what it could be I'm hoping it's not head or head gasket as I just did it.
But I will wait and hear what Rodac says.
- dazza
- Car Make: VW and VW
- Membership No: 1327
If you don't come right at Rodac, then take it to VagSpecCentre they will be able to sort it out first timeHenry@AMF wrote:I'm tired of scratching now. Taking it to Rodac as I don't have the time to fix it.
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
- Henry@AMF
Thanks for the info. I will keep you up to date on what happens.dazza wrote:If you don't come right at Rodac, then take it to VagSpecCentre they will be able to sort it out first timeHenry@AMF wrote:I'm tired of scratching now. Taking it to Rodac as I don't have the time to fix it.
- Henry@AMF
Hi all. I have an update and questions.
I took out my injectors rather before taking car in. Seals are gone and want to know if the copper seal on tip of injector must be moving around or tight on injector?
- Car Make: Audi, Ford
- Car Model: Audi A3 2.0T, Ford Ranger
Hi
I have a 1.9tdi polo with similar problem. The car got water in diesel tank and now has white smoke from start to stop, hot or cold.
Turbo was repaired and timing was checked. The engine has a new head gasket and no oil in water. There is diesel in the oil but with no sign of the injector o-rings leaking. Where can I send the injectors in to around the east rand to test and repair?
Sorry for hijacking the thread.
Destroy engines for science!
Don't want to own the same model car twice!
2006 Audi a3 2.0T fsi
2005 Ford Ranger 2.5 td
1994 Toyota Conquest 1600 16v(RIP)
1989 Opel kadett 1600 gse
1998 Nissan Hardbody 3.0 v6(RIP)
2002 BMW 320i
2007 Polo classic 1.9 TDI
1986 Golf mk2 1600 8v,long list of mods with 36 DCD weber(Soon to be 1.9L 16v)http://www.vwclub.co.za/forum/viewtopic ... 1&t=174876
2002 Opel Corsa C
2002 BMW 320i
2002 Opel Corsa C
I'm not aware of anybody rebuilding PD injectors.
But if anybody can do it , it will be nortern diesel in pretoria.
Google the number, phone them and ask.
- Henry@AMF
No problem. We have to discuss these problems anywhere we can as help could be all over.
I have no idea what is going on with my car. I've done timing 10 times already and still same issue.
No oil in water or water in oil. New head gasket and head was done with new valves, sleeves, seals and lifters.
My guess would be injectors with my car or their seals.
I will know by Monday as car only went in yesterday.
- amstel18
- Car Model: Tiguan Allspace
How did you set the timing? With VCDS? Cause that's the only wayHenry@AMF wrote:No problem. We have to discuss these problems anywhere we can as help could be all over.
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- Henry@AMF
lol. Nope. That's why I'm taking it in. I played around trying to get it close to the best I could on the cam setting.amstel18 wrote:How did you set the timing? With VCDS? Cause that's the only wayHenry@AMF wrote:No problem. We have to discuss these problems anywhere we can as help could be all over.
So still smoking but I don't believe the smoke is because of the timing not set on vcds.
Gave them a call they can rebuild pd injectors, thanks panic.panic-mechanic wrote:I'm not aware of anybody rebuilding PD injectors.
2002 BMW 320i
2002 Opel Corsa C
2002 BMW 320i
2002 Opel Corsa C
- Henry@AMF
Hi guys.
So car is finally fixed. I had everything correct. Injector seals were gone. So Rodac replaced them and white smoke is gone!
I still have to burn out the oil that's caught up in my exhaust by taking a long trip but I'm happy.
Thanks for all the help.
Didn't want to start a new thread for the same topic.
Does anyone know where I can find the pd injector install kit(the 2 big o-rings,small o-ring and copper washer), goldwagen by east rand mall is out of stock and there suppliers is also out?
Second question if you install the injectors how do you set the "rockers" for these injectors?
Thanks in advance.
Thanks in advance.
2002 BMW 320i
2002 Opel Corsa C
2002 BMW 320i
2002 Opel Corsa C
- Henry@AMF
Hey. I know VW has the seals. Rodac replaced mine with Bosch seals but I don't know if they would sell to you. You can give them a try.
For the settings. Try this page.
http://www.a2oc.net/forum/showthread.ph ... aft-1-4tdi
- Henry@AMF
I did not use that gage. Just looked at when the rocker was at its highest point on lobe before I tightened it.
All the way till you feel resistance then 180 degrees back is perfect.
I have a polo 6R 1.4 tdi.the's a white smoke coming from exhaust.its a very big smoke like when the turbo is not working.when I'm driving there is no smoke but when I stop the smoke come out.the car is powerful no sigh of turbo damaged.i dont know what can be the problem.
- NHB_R
Your car bought illegal cigarettes
