hi guys
im new to the site and would like to know what is involved with changing my 74kw turbo to a 96kw turbo.
my car is a 1.9 tdi (74kw)2008 model highline. Would i be able to just take my turbo off and put the 96kw turbo on?
thanks.
polo 1.9 tdi turbo
- Houdini
- Car Model: Golf 5 2.0 TDI
Re: polo 1.9 tdi turbo
Hi man. you would have to weld a straight piece of aluminium pipe on. the 96 kw turbo has the clip in boost pipes. the rest of the stuff will work.
thanks for the response.
the main reason im asking is because volkswagen alpine quoted me R32000 for a new turbo (74kw) and they have a special on at the moment where they selling the 96kw turbo for only R7200? i just dont know how they can justify that price. they said to me i should just put the 96kw turbo on and he said i just need to change the boost line size? may have heard wrong,hence my reason for askng.
thanks
thanks
- Deranged_9n3
- Darth Vader
- Membership No: 1639
Turbo outlet changes. Buy a billet connector from Pieter Fourie & a piece of silicone reducer bend & your sorted
My Youtube Channel
Tiguan Track & Field 4Motion
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Loud 'n Low, Rollin' Coal
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
- Car Model: Polo 9N TDi Sportline, Jetta V
VW had a recall on all 96kw Turbos a while back and in order ensure they had enough , they brought in way too many , so now they are sitting with excess stock - hey it works out perfectly for us end usersBig Norm wrote:the main reason im asking is because volkswagen alpine quoted me R32000 for a new turbo (74kw) and they have a special on at the moment where they selling the 96kw turbo for only R7200? i just dont know how they can justify that price. they said to me i should just put the 96kw turbo on and he said i just need to change the boost line size? may have heard wrong,hence my reason for askng.
thanks
- Morné Pieters
- Registered for: 9 years
- Car Make: VW & Mercedes-Benz
- Car Model: 07 1.9TDi & 09 C350 CDi
Morning BudBig Norm wrote:the main reason im asking is because volkswagen alpine quoted me R32000 for a new turbo (74kw) and they have a special on at the moment where they selling the 96kw turbo for only R7200? i just dont know how they can justify that price. they said to me i should just put the 96kw turbo on and he said i just need to change the boost line size? may have heard wrong,hence my reason for asking.
thanks
I wrote a DIY write up in my rides thread with part numbers, gaskets etc. when I did the conversion below just like:
http://www.vwclub.co.za/forum/viewtopic ... 9&start=75
I agree with everything everyone said so far. The hardware is a direct bolt one expect the turbo outlet for the boost pipe connection as mentioned. The software will need to mapped correctly for the bigger turbo afterwards but you can drive the car as is, it full just not be optimized for power, fuel consumption etc.
Hope this info helps but give me a shout if you need assistance
2007 White Polo 9N3 1.9 TDi (PD100) - Daily Ride (Odo 306 000 km)
PD160 Intake lPD130 Intake System lEGR Blank lPD130 Turbo lDe-Cat lStraight Flow FMIC (450x230x65 mm) & 50 mm S/S Boost Pipes lWulfchip Software lFK Projector Headlights & 6000K HID lLED Retrofit lCustom LED Footwell Lighting lCustom Leather Interior lGTI Black Interior lCustom Speedo Cluster lCruise Control
Vw moveup 2015
Hi guys does anyone perhaps knows the torque settings for the flywheel.im changing the clutch but dont know the flywheel torque settings.
- Morné Pieters
Re: Vw moveup 2015
What bolts are you using? What flywheel? Aftermarket SMF or DMF?
