Flashing glow plug with Check Engine light
- KingBunda
- Car Model: Polo 1.9 TDI Sportline
- Membership No: 3331
So yesterday i took my Polo to VW to change the brake pads, car was fine until i pulled in at my driveway from work, i switched the car off to open the gate when i switched it on the Flashing glow plug with Check Engine light came on,so i drove around the block car was running as normal, what could be the problem?
- Car Model: Mk1 2-Door, Polo Sportline
Re: Flashing glow plug with Check Engine light
For the flashing glow plug light, i would advise you to check that your brakelights are in working order.
It can never be Fast Enuf
- B_rad
- Car Make: Ford
- Car Model: Fiesta ST180
- Membership No: 1835
Glow plug light is probably the brake light switch, under the brake pedal. Check if your brake lights work when the glow plug light is flashing, if not, just get a new one at the dealership!
- KingBunda
Brake lights are working fine, thats the first thing i checked
Then its probably your glow plugs, have it diagnosed...
- KingBunda
Thanks will try and take it to vw tomorrowSchabzo08 wrote:Then its probably your glow plugs, have it diagnosed...
- TimeShifter
- Car Model: 2012 Mk6 GTi
Check your engine oil level, might be on the low side.
2012 VW Golf Mk6 GTi
am I correct in saying (apart from the irritation factor of having the lights flashing), that the glow plug is a "non-event" in South Africa's temperate climate, and that the glow plug is really only needed in sub zero temperatures...?
- Car Model: Polo 1.6TDI
I had the exact same lights on my dashboard.
Scanned the car and got this error:
P2455 - diesel particulate filter pressure sensor 'a' circuit high.
Took it to VW the following day and had the sensor replaced.
- B_rad
- Car Make: Ford
I stand under correction, but a diesel doesn't use a spark plug, so it needs the glow plug to start the car.Atsta wrote:am I correct in saying (apart from the irritation factor of having the lights flashing), that the glow plug is a "non-event" in South Africa's temperate climate, and that the glow plug is really only needed in sub zero temperatures...?
I still think it is the brake light switch, my lights still worked albeit intermittently, when my brake light switch conked out.
If its the 9n3 or 9n, no DPF. If it is the 6R, this may be your problem!6R_TDI wrote:I had the exact same lights on my dashboard.
- B_rad
- Car Make: Ford
Just saw it is a sportline. Therefore no DPF so that is not the problem.
- Tdi jetta 4 ever
Brake light switch, even if the brake lights work it could still be you brake light switch. The brake light switch also send signals to the ECU as its being used while you drive. Have it scanned to make sure.
Robin
robinwisse@gmail.com
- chucker02
- Car Model: Citi ADY
Every diesel needs glowplugs to heat the cylinders in order for the diesel to ignite as a diesel uses compression to ignite the diesel/air mixture. If glowplugs were not present in diesels your car would crank a long time before starting, it would eventually start but with a cloud of smoke coming from the exhaust.
1971 VW beetle
1971 VW beetle
- KingBunda
Howzit gents just got the car scanned at VW and it gave the following error code P0341 no camshaft signal,faults were cleared but i'm still not at ease, thanks for the help gents
- Tdi jetta 4 ever
KingBunda wrote:Howzit gents just got the car scanned at VW and it gave the following error code P0341 no camshaft signal,faults were cleared but i'm still not at ease, thanks for the help gents
Thats odd. Isnt it supposed to give the check engine warning only? I wonder why the glow plug light also flashed ?
Robin
- Bird87_ZA
- Major-General
- Car Model: CrossPolo 1.6TDI
- Membership No: 1515
Got exactly the same. VW is convinced that it's the tail lights I bought from them causing the glow plug and check engine light.6R_TDI wrote:I had the exact same lights on my dashboard.
Car is going in on Monday, for the THIRD time for this.
2001 Bantam 1.6 Lesuire - RIP
2007 Polo 1.6 Comfortline - SOLD
2007 Polo 1.9 TDI Highline - STOLEN
2011 Polo 1.6 TDI Cross - SOLD
2014 Golf 7 SV 1.2TSI
Web Developer by day, Couch Potato by night.
Neuk wrote:A pole, doth not a lie tell...
Hi Guys,
I have the same light flashing on my 2006 1.9 TDi but only if I switch on the headlights and also then the speed(cruise control) control does not work. Driving on the open road with headlights on no speed control, switch off the head lights switch on the speed control working turn on the lights???
Already checked the break light switch working well, the two front fog lights US though?
Any advice suggestions will be appreciated.
- Sinbad
- Post Whore
- Car Make: Mercedes
- Membership No: 1152
Incorrect.chucker02 wrote:Every diesel needs glowplugs to heat the cylinders in order for the diesel to ignite as a diesel uses compression to ignite the diesel/air mixture. If glowplugs were not present in diesels your car would crank a long time before starting, it would eventually start but with a cloud of smoke coming from the exhaust.
Glowplugs are only actually needed when ambient temperatures are way below freezing.
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
But surely the air doesn't get very hot when it gets compressed 16-19 times?Sinbad wrote:Incorrect.chucker02 wrote:Every diesel needs glowplugs to heat the cylinders in order for the diesel to ignite as a diesel uses compression to ignite the diesel/air mixture. If glowplugs were not present in diesels your car would crank a long time before starting, it would eventually start but with a cloud of smoke coming from the exhaust.
- amstel18
- Car Model: Tiguan Allspace
I read the pd technical article in the faq section last night. Glow plugs are used when coolant temp is below 9degrees celcius
Sent from my GT-I9100 using Tapatalk 2
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- Sinbad
- Post Whore
30 degree input air, 500c volume (2l engine), 18:1 compression, the air temp at the top of the compression stroke assuming no heat transfer anywhere is 680 degrees CVGTI wrote:But surely the air doesn't get very hot when it gets compressed 16-19 times?Sinbad wrote:Incorrect.chucker02 wrote:Every diesel needs glowplugs to heat the cylinders in order for the diesel to ignite as a diesel uses compression to ignite the diesel/air mixture. If glowplugs were not present in diesels your car would crank a long time before starting, it would eventually start but with a cloud of smoke coming from the exhaust.
Diesel auto-ignition temperature is around 210-250 degrees C.
- chucker02
Ok disconnect your glowplugs and try to start it on a cold morning. Youll see what I mean
1971 VW beetle
1971 VW beetle
- Membership No: 388
Dissconnect the glow plugs the car will start in our temps. They correct it will only work below 9deg.
We get the tdis in with high milage and non functioning glow plugs customers dont even know it.
The tdi with non working ccs when lights are on. Check the brake light globes msybe you have a single contact globe in were a double should be so it back feeds into the brake circuitmakeing the ecu thinck u pressing brakes.
Polo came with the ywomdiff tail loghts one is double while other is single.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
- chucker02
Maybe the vw tdis but the jeep diesels struggle to start with non working glow plugs
1971 VW beetle
1971 VW beetle
- Bird87_ZA
- Major-General
Jeeps struggle to start with working glow plugs too.chucker02 wrote:Maybe the vw tdis but the jeep diesels struggle to start with non working glow plugs
