83.5mm pistons
Membership queries? More info? Problems? Post here and the Committee will get back to you
This is NOT for technical or brand-related questions.
Megan84klassen
83.5mm pistons
Post by Megan84klassen »
Hi guys fairly new to the game, what I like to know is I've got 2.0 8v AGG engine with piston slap. I Wanna bore it to 83.5mm / 40thou with standard crank and flowed head with 276 cam. Problem I have is the oil pump which one to get for proper pressure hot or cold and the pistons. I'm little lost with the pistons. Any advice appreciate. I called alert the guy asked me isit the small or big piston, apparently the 2e piston is different. Thanks
