280mm bolt on Brake upgrade kits for MK1 is here!!!
Delarey Racing Developments specializes in standard automotive and custom performance automotive parts
Viper
Goldwagen Delarey
Car Model: GOLF 1 1870cc 8v ethanol
Membership No: 1800
Post by Viper »
Hi we have landed our brake upgrade brackets.
The brackets have been designed in house and have been made on a CNC precision milling machine out of high grade aluminum.
We have been testing the bracket the hole of last year and are very happy with the performance.
The kit will upgrade your 237mm disc to a 280mm 4/100 pcd polo cup discs and you re-use your std golf caliper for this upgrade. The mk1 golf is light enough so they work fine. The nice thing with this upgrade is that you wont have a problem with the caliper rubbing the mag or rim because of the bigger offset compare to the vr6 brake upgrade. I have got 10 sets discs and bracket in stock. I do not carry large number of ebc pads, so if you option for some ebc pads we must just check stock.
NB: mag or min size must be 15" or larger
Polo cup discs R1282.00 per set
Brackets R920.00 per set (incl 8.8 HT bolts)
Brake pads: R207.00 ferodo
Installation R500.00
Price update 31/10/2016
Life160
Registered for: 19 years 8 months
Re: 280mm bolt on Brake upgrade kits for MK1 is here!!!
Post by Life160 »
Cant see the images from work - but do you have a 5/100 option? Also assuming that this would work on my VR6 wheel?
Available exclusively at your store?
Also - how does this differ from the Volkspares equivalent (quality)?
MK6 GTI 12' (APR)
Citi Life 01' - 1.6i 8v :(
76.6kw/144nm (RBTS)
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Life160 wrote:Cant see the images from work - but do you have a 5/100 option? Also assuming that this would work on my VR6 wheel?
The disc you can buy from any GW, but the brackets is only available at this store . At this point of time we only do it in 4/100 pcd and the vr6 disc will not fit this setup sorry :oops: I will have look and see if there is a 5/100 disc that may fit and then come back to you.
Go and have a look at the Volkspares setup and then have a look at mine. You should be able to answer that question your self then :grin:
Gielie
Registered for: 12 years 4 months
Car Make: Toyota
Car Model: Heeelooks
Membership No: 1729
Post by Gielie »
Now this is :drool: :drool: :drool:
Also sorts my problems regarding going 15" with the volkspares kit.
Now to see what the bank manger says.
Life160
Post by Life160 »
Will wait for your response.
MK6 GTI 12' (APR)
76.6kw/144nm (RBTS)
Abnormal
Registered for: 19 years 11 months
Membership No: 848
Post by Abnormal »
Viper wrote:*snip* The mk1 golf is light enough so they work fine. *snip*
Why do you say this?
is there a risk of failure if the vehicle is heavier?
looks really good
\Oo) \ _w_ / (oO/
Life160
Post by Life160 »
Gielie01 wrote:Now this is :drool: :drool: :drool:
So the Volkspares kit doesnt work with 15" wheels?
MK6 GTI 12' (APR)
76.6kw/144nm (RBTS)
Gielie
Car Make: Toyota
Membership No: 1729
Post by Gielie »
I have the volkspares kit on my Caddy and it is a pain to find 15" wheels that clear the brakes.
The velo wheels clear as far as I am aware.
But the wheels I have liked so far just don't clear them.
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
looks really good
There is no need to go with a bigger caliper. Meany ok's think with with bigger discs you need bigger calipers, but on a mk1 bigger discs works just fine with std calipers . Do not get me wrong . I wouldn't mind a set of 4 or 6 pod calipers but that just but it in another price league. If any one wonder how good this brake upgrade kit is . Just join us on the next track day or swing by the shop and i will take you for a demo :driving:
Abnormal
Membership No: 848
Post by Abnormal »
Ok makes sense
\Oo) \ _w_ / (oO/
Life160
Post by Life160 »
Hi
Please keep me posted on what other disc you may have.
Alternatively - I have two options: drill these ones or buy 5/100 from Volkspares and buy the adapters from you.
The only issue is getting the 1st ones drilled. I dont have time to take it to Norbrake - considering I live in the Rivonia.
MK6 GTI 12' (APR)
76.6kw/144nm (RBTS)
Abnormal
Membership No: 848
Post by Abnormal »
The 5 x 100 vr6 wont work because the offset will be different.
Not sure about other 5 x 100 discs.
\Oo) \ _w_ / (oO/
Nizmo Racer
Post by Nizmo Racer »
Gielie01 wrote:I have the volkspares kit on my Caddy and it is a pain to find 15" wheels that clear the brakes.
You right the volkspares disc and adapters clears the velo rims...
I think it all depends on the rims offset (et),i cant remember what were the rims i tried et but i know they were 7 and 7.5j in the front no issues....
16 Golf 6 Gti Cabrio
06 Velociti 1.4i
07 Caddy 20VT
Ex 08 Golf 5 Gti K04
Ex 07 Velociti 1.4i
Ex 06 Citi 1.4i
Ex 91 Caddy 1.8 Gti
Ex 10 Audi TSI
EX 06 Velo 1.6i
EX 06 Citi 1.4i
EX '85 Golf 1
GTiDon
Membership No: 1161
Post by GTiDon »
Can I test/fit one of my rims on this setup before buying?
Are the brake pads used different to standard?
Funny Pic
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
gtidon wrote:Can I test/fit one of my rims on this setup before buying?
Funny Pic
We can do a test fit on my car if you want (same setup).
Same pads as the std setup!
Life160
Post by Life160 »
What would it cost if you had to get me a 4/100 disc drilled to 5/100?
MK6 GTI 12' (APR)
76.6kw/144nm (RBTS)
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Ok i went throw all the discs we stock and the closest fit is a mk4 280mm disc bit the ofset is less so the caliper do not seat properly. I think the best solution is to get the 4/100 drilled to 5/100. I see if i can get a price for you and come back. :grin:
Life160
Post by Life160 »
Viper wrote:Ok i went throw all the discs we stock and the closest fit is a mk4 280mm disc bit the ofset is less so the caliper do not seat properly. I think the best solution is to get the 4/100 drilled to 5/100. I see if i can get a price for you and come back. :grin:
Appreciated...
MK6 GTI 12' (APR)
76.6kw/144nm (RBTS)
Koosie101
Registered for: 10 years 11 months
Car Model: Cross Up! 2017 1.0 mpi
Post by Koosie101 »
Hi, Ive got the standard size cross drilled ventilated discs on mine... Also aught them from goldwagen. Maybe thats a cheaper alternative if your mags dont fit...
Will take a pic today and post it. They do improve braking. they dont fade as fast and cools down much faster. maybe only a 10% increase in wear on the ATE pads.
ps. These are ATE discs.
Current Ride: VW Cross Up! 1.0 mpi 2017 : https://www.vwclub.co.za/forum/viewtopi ... 1&t=203088
Previous Rides: VW Jetta CSX 1997 : http://vwclub.co.za/forum/viewtopic.php ... 5#p2352115
VW Citi Sport 1.4i 2008
VW Golf mk5 2.0. 2007
VW Jetta mk2 2.0I 8V MP9, 1990
VW Jetta mk2 2.0 1989
Naku786
Cake Laaitie Killer
Car Model: Citi 1.9i 8v
Post by Naku786 »
Life160 wrote:What would it cost if you had to get me a 4/100 disc drilled to 5/100?
why not fit stock vr6 disc? its 5x100 288mm
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Vr6 disc offset is different to the 280mm 4/100 disc. So problems with caliper rubbing the mag :bang:
Naku786
Cake Laaitie Killer
Post by Naku786 »
we use to grind what touched back in the day :lol:
dubdude
Car Model: citi.com
Membership No: 1883
Post by dubdude »
can i get these discs from vw?
Dejan
Citi.com - 2.0L 8v
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
dubdude wrote:can i get these discs from vw?
I don't think so . But why?
Sent from my GT-N7105 using Tapatalk 2
dubdude
Car Model: citi.com
Membership No: 1883
Post by dubdude »
so i can put them on my account :evil:
how much will it cost me from u? discs adapters and pads? what are the best pads?
what discs are these? where they made by vw once?
Dejan
Citi.com - 2.0L 8v
