280mm bolt on Brake upgrade kits for MK1 is here!!!
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
Re: 280mm bolt on Brake upgrade kits for MK1 is here!!!
looks like it was written in blood
- Car Model: vw mk1 caddy
Viper wrote:Jip we fount that on a few of the older mk1's. The casting are very rough and we needed to clean the the part up using a grinder just make them fit more snugly. Your calipers have been modded BTW, some one removed the front bar between the upper and lower part of the caliper
This callipers has ben giving me problems.....the is always that cluttering sound
I thought that's how the old model callipers look like.....
any1 who has a picture of wholly callipers like the ones I have here
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
Current rides:
Hyundai - 1.4 Getz (daily)
You should be able to get carriers from a scrappie, might even get for free
- General
One of the guys on the Forum got his GT cut like that as well, the calliper carrier was forced (bend) open (support gone) leading to all sorts of issues. That is a standard Citi/Chico calliper carrier, must be thousands of them in the scrapyards. Just check your wheel clearance, reason the guys cut them is to clear aftermarket mag wheels.
Current rides:
bud..... will sort that outTorker wrote:One of the guys on the Forum got his GT cut like that as well, the calliper carrier was forced (bend) open (support gone) leading to all sorts of issues. That is a standard Citi/Chico calliper carrier, must be thousands of them in the scrapyards. Just check your wheel clearance, reason the guys cut them is to clear aftermarket mag wheels.
- Car Model: MK 7 R
- Membership No: 3011
Do you guys sell these disc in slotted and drilled maybe otherwise where will i get that is exactly the same size as these ones, and just for interest sake how does the bigger discs help for braking
ex
Blue Smurf (MK1 Chico Golf 2.1 L )
Silver Surfer (MK4 GTI)
Jeep Grand Cherokee SRT8
Present
@fearless_mk7R (VW Golf MK7 R )
Present
- Car Model: MK 7 R
What discs are those and where did you get them looks really nice looks like 280mm if im not mistaken
ex
Present
Present
- Goldwagen Delarey
- Car Model: GOLF 1 1870cc 8v ethanol
- Membership No: 1800
Unfortunately we don't sell them slotted or drilled because it's not needed. I do track with mine and have never over heated the pads or got brake fade with ETC yellow. If the car was fatter maybe yes but the mk1 weighs nothing.
Sent from my GT-N7105 using Tapatalk
- Membership No: 1161
But looks a lot coolerViper wrote:Unfortunately we don't sell them slotted or drilled because it's not needed. I do track with mine and have never over heated the pads or got brake fade with ETC yellow. If the car was fatter maybe yes but the mk1 weighs nothing.
Sent from my C6603 using Tapatalk
- General
I bough that kit (288 x 28) on the forum many years ago, gave me sterling service, over 100k km's, I replaced it with one of Wikus's kits a while back. I need to get the disks replaced (some engineering involved), it will probably find it's way back onto one of my Golfs, problem is that it limits you with regards to 15" wheels, the only wheels that it worked on so far are Velo wheels.
Current rides:
- Car Model: Golf 2.0 8v
i need a set of these please contact me im interested
PM Viper/Ashley1.8T on make a trip to GW DelerayPriveshin wrote:i need a set of these please contact me im interested
Will do thanks
- 6teen_valve
- Car Model: Sooter, Money pit
- Membership No: 1406
will this bracket fit golf 2 gti bearing carrier??? to take 280 disk??
89' MkII Golf
Ex:2003 1.4i CiTi
Ex:2004 1.6 16v Opel
Ex:2002 2.0i 8v Caddy
Ex:08' Sooty - Stolen
''anybody can go out and buy a new hot hatch
it takes a special kind of crazy to restore a mk2 to its former glory''
Membership No: 1406
Ex:2003 1.4i CiTi
Membership No: 1406
- Goldwagen Delarey
No sorry!
- Car Model: Golf 6.:R
hey guys
i fitted this kit to my project but im having a small issue
the disc is sitting way to close to the carrier...
ive spoken to viper about this and he also hasn't experienced this before
anybody else seen this before?
any ideas as to why this could be happening?
both sides are doing the EXACT same
vw is the best, f*#k the rest!!!
My Citi build!
My Citi build!
did you modify the bracket that comes with the kit in any way?
nope . I did have to grind away on the knuckle to get the bolts alligned thoNaku786 wrote:did you modify the bracket that comes with the kit in any way?
My Citi build!
My Citi build!
- Goldwagen Delarey
Have you sorted out the wheel bearing and hub issue we talked about last night?ShafiqNC wrote:hey guys
Please tighten down the center cv nut and use the wheel bolts to bolt down the disc . If the disc is not moving true or you got any movement it will cause issues
Untill you have done this we cant go further
- moonwillow
- Registered for: 10 years 9 months
- Car Model: 2L Caddy
Here comes a silly question
if your brakes overheated do you need to replace the pads? I replaced my solid disk with vented a while back and did notice better braking.
@Viper I will be calling you for a kit end of the month.
Current rides.
1998 VW Caddy 2L 8v.
2015 Renault Clio
ex rides.
1998 Hyundai Elantra 1.8
2007 Mazda RX8 Hi-Speed
2007 Chev Lumina SS 6L V8
2010 Mazda BT50 3L 4x4
2010 Hyundai Elantra 1.6
1999 VW Chico 1.3 Carb
2005 VW Caddy 1.6
2007 Suzuki GSXR 750
2009 Citi ROX 1.4i
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=159156
2015 Renault Clio
ex rides.
2005 VW Caddy 1.6
2009 Citi ROX 1.4i
How overheated? Ive read race drivers recommend overheating new pads right after installing them.moonwillow wrote:Here comes a silly question
- General
Yeah - it's called bedding the brakes in...GTiDon wrote:How overheated? Ive read race drivers recommend overheating new pads right after installing them.moonwillow wrote:Here comes a silly question
Current rides:
- moonwillow
It was smoking. Almot looked like my engine was on fire
Current rides.
2015 Renault Clio
ex rides.
2005 VW Caddy 1.6
2009 Citi ROX 1.4i
2015 Renault Clio
ex rides.
2005 VW Caddy 1.6
2009 Citi ROX 1.4i
