NF Sport
NF provides a range of high quality products that solve a wide range of fuel problems and are unique, very affordable and achieve amazing results!
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
NF Sport
Post by VWicked »
Hi,
Is it only recommended to add a bottle of NF sport to a full tank of fuel or can you add it to say 25 litres? Will this increase the octane of the fuel even more?
Reason im asking is that with NF ultra it states that you can add to a variety of fuel amount for different RONs, does same apply to sport?
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
NF.
Fuel Additive Specialist
Car Make: Subaru
Car Model: STi 6 Type-RA 555 V-Limited
Re: NF Sport
Post by NF. »
NF Sport is designed to treat a full tank of petrol. I wouldn't put it in anything less than 45 litres. Putting it in less petrol will give you a slightly higher octane. If you're looking for higher octane I would suggest using the NF Ultra instead.
NF Ultra Race Fuel Concentrate has a completely different formula and different active ingredients to the NF Octane Boosters which is why it is safe to run in higher concentrations.
VWicked
Membership No: 1492
Re: NF Sport
Post by VWicked »
Thank you, makes sense.
Re: NF Sport
Post by dood786 »
So what happens if you put nf sport into only 25 litres?
NF.
Car Make: Subaru
Re: NF Sport
Post by NF. »
dood786 wrote:So what happens if you put nf sport into only 25 litres?
At that dosage you are overdosing (by more than double) and are likely to foul your spark plugs.
On the plus side the car will go very well!
Re: NF Sport
Post by dood786 »
Double Doses FTW :hi:
Thanx
graham savage
Membership No: 803
Re: NF Sport
Post by graham savage »
I've double dosed tje Ranger with ultra, it does have a 80L tank though... Great improvement! But gets costly, especially seeing as though footing it around it kills the tank in 350km... Thats around R4/km
GrImMy
Membership No: 1838
Re: NF Sport
Post by GrImMy »
Just a question, I usually fill up to automatic stop which is about 40l, given that I have about 5 liters left in the tank (not sure though).. Will it be OK for me to put a whole bottle of NF Sport in my tank on less than 50l? I see it treats 60l and I really don't want to foul my plugs... Also does it matter if its put in before the refill or after?
NF.
Car Make: Subaru
Re: NF Sport
Post by NF. »
GrImMy wrote:Just a question, I usually fill up to automatic stop which is about 40l, given that I have about 5 liters left in the tank (not sure though).. Will it be OK for me to put a whole bottle of NF Sport in my tank on less than 50l? I see it treats 60l and I really don't want to foul my plugs... Also does it matter if its put in before the refill or after?
It will be ok to use NF Sport in 45 litres of fuel. If you are using it in every tank I would suggest not using the NF Sport in about every 5th tank to make sure it doesn't build up in the tank.
It is best to pour it in before you fill up to make sure you get a good mix as the tank fills.
GrImMy
Membership No: 1838
Re: NF Sport
Post by GrImMy »
Thanks. This is my first use of NF so I'm excited to see the gains! Cant wait!
SemiColon
I sparkle in the sunlight
Car Make: Volvo
Car Model: S40 T5
Membership No: 1641
Re: NF Sport
Post by SemiColon »
Oh sheet, ive been using a bottle(NF Sport) for every 40L, and is on tank Nr 7 now :crazy:
八拾六
