Polo 7 draining battery overnight
Andemandoyi
Post by Andemandoyi »
I have a polo tsi 2014 model that keeps draining the battery when the ignition is off. The current is around 7Amps and only stop when I either disconnect the battery or take out fuse SC38 (description says "onboard supply control unit J519"). Kindly provide assistance as to what could be draining it. VCDS wasn't much help either.
PapaJo
Registered for: 14 years
Car Make: VW's
Re: Polo 7 draining battery overnight
Post by PapaJo »
2014 model, Polo 7?
The correct way to diagnose this fault would be to go to a VW dealership for proper diagnostics. 2014 model should still be under maintenance plan if you have selected that when purchased. It could also come from any other circuits, which is fed from this fuse SC38, on board control unit.
This unit deactivates convenience system consumers and long-term HT consumers e.g. heated rear windscreen, so that heavy discharging of the battery is avoided.
Is this car fitted with a tracking device, aftermarket radio or was it accident damaged, possible disturbance in factory wiring?
Andemandoyi
It does have a tracking device
PapaJo
Car Make: VW's
Post by PapaJo »
I suggest that you make an appointment with your local VW dealership and ask them to run a full diagnostics check on your car. Will cost you around R750 if you are out of your maintenance or service plan.
Ashveer03
Post by Ashveer03 »
7 amps is a massive drain. The most i have seen in parasitic draw was 3amps.
Are u sure that EVERYTHING was turned off during the test?
Andemandoyi
Yes. Everything as off
Ashveer03
Post by Ashveer03 »
Well if u dont want to go to a dealership/workshop and u want to diy then u gonna haveto get urself a wiring diagram. I wouldnt advise taking a chance without it..
Mbuzi
Car Model: Q5
Membership No: 1964
Post by Mbuzi »
Andemandoyi wrote: Sat Apr 21, 2018 10:11 pm I have a polo tsi 2014 model that keeps draining the battery when the ignition is off. The current is around 7Amps and only stop when I either disconnect the battery or take out fuse SC38 (description says "onboard supply control unit J519"). Kindly provide assistance as to what could be draining it. VCDS wasn't much help either.
Post moved to Tech discussion
