Product/s review
GaVeN
Committee Member
Car Model: A4 B8 Sooter
Product/s review
Post by GaVeN »
There's not a whole lot of reviews done on products available.
And, there's definitely a boat load of them on the market with each claiming to be the newest & best.
I will keep updating this thread as I get hold of some products, and write my reviews on them to help clear up some of the guess work for the beginners & someone looking for a product.
Carchem APC - Citrus:
The good:
I got some from Jason at Diamond worx detailing upon his recommendation.
Smells awesome & turns a funky greenish colour when applied to dirty surfaces
The not so good:
As an APC to help remove medium soiling & grease, it works great. As a method of "stripping" paint in preparation for a full detail it works great.
Where it lacks is on heavy caked on grease & dirt.
Where it failed:
I used it on an engine that hasn't seen a wash in 19 years & 240 000km. Did not remove more caked on grease than Prepsol water based degreaser removed.
I used it on a set of wheels I bought, agitated, left to dwell, sprayed on again & still did not remove the dirt as well as I would've hoped.
This was undiluted I might add.
Closing:
If you use it to maintain a lightly soiled area, or to prep for a full detail, it is the product to use.
I give it a 7/10
LostEnigma
Registered for: 10 years 11 months
Car Model: S3 8L
Membership No: 3207
Re: Product/s review
Post by LostEnigma »
Finally some one else giving me feedback.. Will see what can be done to make it attack more troublesome dirt!
Thank you oom!
2003 Mexico Blue Audi S3 8L 280.7 WKW - 424NM - Bagged by FS Projects, YT Revision & Only Charged Dubs - ISPIRI WHEELS FTW
2013 VW Candy White Polo Vivo GT - SOLD
1997 VW White Chico Golf - SOLD
GaVeN
Committee Member
Post by GaVeN »
Auto finesse iron out
The good:
Smells vile (Like it should)
The not so good:
I used some on 3 sets of wheels so far, and the results were great. These are on wheels that are washed weekly & have little soiling on them.
Where it failed:
I 1st used Gyeon Iron & this stuff kicks butt. Turns purple almost instantly and attacks the iron particles, then turns copper colour when the reaction is done. THis process takes 1-2 minutes & smell is awful.
I used Auto finesse after, and somehow it is not as potent as I had expected. It takes about 4-5 minutes to turn a nice purple where you can see it dissolve the iron particles, and I've only once seen it turn copper after about 10 minutes of surface contact time & a fair amount of agitation.
Closing:
If you are a cautious person wanting to get a product that works slow & want to agitate the surface to yield results, or you have the time to do a 2nd pass on your surface, this is your product.
If you have heavily soiled wheels with high mileage of baked in contaminents, this will be frustrating for you to work with. Opt for Gyeon Iron instead
I give it a 7/10
LostEnigma
Car Model: S3 8L
Membership No: 3207
GaVeN wrote:Auto finesse iron out
The good:
The not so good:
Where it failed:
Closing:
I give it a 7/10
First time I have had someone say anything has beaten iron out..
Time to get you some CarChem Revolt... I use the 2 from time to time and they both hit dirt that the other wasn't picking up..
:hurray: Appreciate your reviews as always!
GaVeN
Committee Member
Post by GaVeN »
Sonax wheel cleaner
The good:
Readily available at Builders warehouse & most Spares shops.
Price is on par with other de-ironising products
Smells great in comparison with other de-ironising cleaners available
When applied, it is has a gel like formulation that doesn't run off as quick as other de-ironising cleaners, which gives it very decent dwelling time
The not so good:
The performance is actually disgustingly poor. On wheel faces it barely desolves anything, although it turns purple upon impact on discs where the brake dust is present
Where it failed:
Used a full bottle on one wheel of a car as a test. I am still left with stubborn brake dust embedded in the paint that it simply can't get off.
Closing:
I would recommend this as a weekly regimen cleaner for your wheels to maintain.
I will go buy a bottle of this & dilute with Auto finesse iron out, or Gyeon Iron to give those 2 products a thicker viscosity to have longer surface contact time
Price of this, versus the price of Gyeon or Auto finesse is ridiculous when comparing the effectiveness.
I would've needed 4 bottles @R120 each to clean 4 wheels. I can do 4-5 sets of wheels with Gyeon or Auto finesse iron for the same price as one of these Sonax bottles
I give it a 3/10
GaVeN
Committee Member
Post by GaVeN »
Turtle wax - Bug & tar remover
The good:
Smells delicious, and viscosity is awesome. It hardly runs off of even a completely vertical panel such as wheel arches
The not so good:
Used it on some heavily soiled arches. Softens up microns of the top layer, but is a bit lacking
Where it failed:
I had to use a full bar of clay & a full bottle of the product to remove 4 wheel arches of hardened tar.
Closing:
For bugs on the front-end, it works very well without being too aggressive
On dried out tar on arches & wheels, it lacks quite a bit
I've seen other products where you can see those products soften up & almost dislodge tar spots from wheels, whereas this needs agitation or even a clay bar to pick the surface tar & bug remains up
I give it a 5/10
PoLonY
Registered for: 14 years 9 months
Car Model: A8
Membership No: 1997
Post by PoLonY »
10/10 would read again
GaVeN
Committee Member
Post by GaVeN »
Gyeon Bathe +
The good:
Smells awesome
Presentation of the Gyeon products are very classy
Works very well and good value for money
The not so good:
I can't fault the product
Where it failed:
I can see no fault in it
Closing:
Suds on this is unbelievable
I use one cap of concentrate to 5litres of water & the lubrication & cleaning ability is fantastic
I have done about 20 washes and there's still 1/3 of a bottle left
Have not compared to other PH neutral shampoo's on the market
I give it a 9/10
Saiendra
Criminal Troll.
Car Model: 2019 Polo Vivo 1.4 C/Line
Post by Saiendra »
GaVeN wrote:Gyeon Bathe +
The good:
Smells awesome
The not so good:
Where it failed:
Closing:
I give it a 9/10
fan boy :lol:
jk, Does Jason stock this?
Daily - Limestone Grey 2019 Volkswagen Polo Vivo 1.4 Comfortline.
GaVeN
Committee Member
Post by GaVeN »
Nope, not a Gyeon fan boy at all.
If a product works, it works.
Just trying to give a fair review on products available that I have personally used.
Jason can get these products for you if you request it
LostEnigma
Car Model: S3 8L
Membership No: 3207
SAI.. Can make a plan for you... Seen plenty people on this forum saying the CarChem luxury shampoo doesn't work when used to recommended dosage... But I don't use any products to recommended dosage..
I mix and match products to make my detailing as easy and enjoyable as possible. I'd try the luxury shampoo before using Gyeon.. But I am a CarChem fanboy!
Saiendra
Criminal Troll.
Post by Saiendra »
GaVeN wrote:Nope, not a Gyeon fan boy at all.
was kidding.
LostEnigma wrote:SAI.. Can make a plan for you... Seen plenty people on this forum saying the CarChem luxury shampoo doesn't work when used to recommended dosage... But I don't use any products to recommended dosage..
it's not that I'm unhappy with the carchem stuff, just wanna try something different since gav says its awesome.
GaVeN
Committee Member
Post by GaVeN »
Sai, I know you were kidding.
I can decant some Gyeon for you to try and you can decided for yourself.
Maybe bring me some Carchem shampoo to try as a comparison?
Registered for: 13 years 8 months
First off, nice post and thanks for putting together all the feedback Gaven :hurray: :hug:
LostEnigma wrote:First time I have had someone say anything has beaten iron out..
I have stated many times on this forum that I prefer Valet Pro Dragon's Breath, Carpro Iron-x and Carchem Revolt to Autofinesse Iron Out.... the iron out doesn't cling well enough and dries out too quickly...
GaVeN wrote:Sonax wheel cleaner
I wouldn't.... in fact I would not recommend ANY wheel cleaner to be used weekly...unless it was completely PH neutral. The idea is to NOT keep hitting the wheel surface with harsh chemicals... instead what you should try and aim for is to use a PH neutral car shampoo or dedicated PH Neutral wheel cleaner for your cleaning, and ONLY when that doesn't cut it, use a wheel cleaner...
An example may be:
Weekly washes - ph neutral
Once a month clean - dedicated wheel cleaner + re-seal
Once a quarter or once every 2nd quarter - dedicated wheel cleaner + de-iron + re-seal
GaVeN wrote:Turtle wax - Bug & tar remover
Just a small tip.... if you have to tackle large volumes of tar like in wheel arches, you can always use mineral spirits which will work out way more economical... essentially mineral spirits is the 'base' used in many hydrocarbon tar removers. It is basically kerosene with the nasty stuff removed.
It will be more difficult to remove because it is totally water insoluble and also it has a relatively high flash point so it can take hours to evaporate away (and you cannot afford to apply something until it is all gone) so you will need to give the area a decent wash afterwards (not simply just wipe away like a dedicated tar remover which flashes away on its own).
It is 'paint safe' should you chose to use it on the paint itself, but typically the volume of tar in these areas is significantly less, and therefore the 'ease of use' of a dedicated tar remover outweighs the cost savings, IMO.
LostEnigma
Car Model: S3 8L
Membership No: 3207
lawrence wrote:First off, nice post and thanks for putting together all the feedback Gaven :hurray: :hug:
An example may be:
Agree with everything lawrence has said besides VP Dragon's Breath..
I can't say it's better than AF Iron Out... Nevermind Revolt..
I have found De-Ironizerresersersersersers... have pulled greater results when used with sudz still running on the car.
I do know that Iron Out does say it should be left for 10-15 minutes!
LostEnigma wrote:De-Ironizerresersersersersers...
:lol: :lol: :lol:
LostEnigma
Car Model: S3 8L
Membership No: 3207
:lol: :lol: :lol:
You laugh... tongue twister of note.. Okay back on topic :hug:
GaVeN
Committee Member
Post by GaVeN »
Lawrence you biscuit.
Thanks for the input as always.
Sonax is so weak, I have no issue using it on my wheels once a week and giving my wheels a quick wipe with quick detailer, or even washing it with a wash & wax. It really does so little to iron deposits on the wheel face (read hardly anything) that I am comfortable using it weekly. My opinion of course.
As far as other Iron products go, I'd love to try a few out.
Maybe Jason has some in stock, and we can try 4 different products on a set of wheels and compare apples with apples?
mikhail117
Registered for: 9 years 1 month
Car Make: Volkwagen
Car Model: CW Polo 6R GTi
Post by mikhail117 »
I like this!
:hurray: :hurray:
Lawrence, Zubair and I we're just the other day talking about unbiased reviews and how much money you'd save if you could differentiate between all the greats and the no not-so-greats. I appreciate the feedback on the products and agree with your views on the few products mentioned here that I have used.
Awesome idea with great feedback, looking forward to future reviews :type:
Mikhail Petersen
mjpetersen@mweb.co.za
GaVeN
Committee Member
Post by GaVeN »
mikhail117 wrote:I like this!
:hurray: :hurray:
Thanks guy
You guys also use a boatload of different products, so please also join in & give your reviews.
I most certainly would appreciate the feedback
There are some pics in this thread showing the effectiveness of Valet Pro Advanced Neutral Snowfoam, should anyone wish to see.
http://www.vwclub.co.za/forum/viewtopic ... 0&t=197451
My thoughts...
I like the smell - citrus (obviaas)
IT WORKS
It's not the most clingy, but it isn't the most runny either
I typically use around 300ml of (mixed) solution to foam a car, so the cost per application is around R8.33 @ 1:10
ace_the_house_cat
Registered for: 11 years 11 months
Car Model: Mr Bean-Mobile
Post by ace_the_house_cat »
Great reviews, keep them coming :hurray: Even a noob like me understands this (most of it at least :fear: )
Slightly off topic; what would you recommend the best "all-round" rim cleaner is (value for money, availability, product strength. etc?)
His: MINI JCW GP2
Hers: AUDI TT 3.2 Roadster
Ex: AUDI TTS Roadster
Ex: RenaultSport Megane RB8
Ex: RenaultSport Clio 4 EDC
Ex: RenaultSport Clio 3
Ex: MK3 Polo Playa
ace_the_house_cat wrote:Slightly off topic; what would you recommend the best "all-round" rim cleaner is (value for money, availability, product strength. etc?)
Something you can dilute to suit your purpose.
My personal favorites - Angel Wax's Billberry closely followed by Valet Pro's Billberry.
ace_the_house_cat
Thanks! Will check it out! :hug:
His: MINI JCW GP2
Ex: MK3 Polo Playa
Djin
Crazydetailer
Registered for: 20 years 9 months
Post by Djin »
Nice thread! :cool:
Great way to get actual user opinions on the products that are used by most of us. :thumbup:
Website : - http://www.crazydetailer.co.za
Email - Info@crazydetailer.co.za
Shop 8. WorldWear Center, Fairlands, JHB
Store Tel : 011 476 5409
