Polo 9N Info and DIY guides
- Registered for: 15 years
- Car Model: 2004 Polo TDI Sportline
I've complied a list of info and DIY guides for 9N-9N3 Polo's.This is by no means any of my work but i've simply gathered links from various forums and websites to put them in one big pile making it easier for everyone to find.If anyone has any more links for DIY jobs pertaining to Polo's please post.If the info you looking for is not in here then you can certainly find it here http://translate.google.co.za/translate ... ry_state0=
[9N-9N3]
Exterior:
Body kits http://www.vwwatercooled.org.au/newforu ... hp?t=11376
Front Splitter http://www.vwwatercooled.org.au/newforu ... php?t=4801
9N Grill Removal Guide http://74.125.91.132/translate_c?hl=en& ... zSvyirBfaw
9N3 Grill Removal Guide http://74.125.91.132/translate_c?hl=en& ... _O8vV_UHyw
Roof Aerial Replacement
http://www.tigerstyle.co.uk/phpBB3/view ... 10&t=22516
How to Dismantle Front Bumper
http://74.125.91.132/translate_c?hl=en& ... 6se7eBbebw
How to Dismantle Rear Bumper
http://74.125.91.132/translate_c?hl=en& ... utWamcVEJQ
Tips for painting of parts
http://74.125.91.132/translate_c?hl=en& ... Sk_Q_0tHVQ
[9N-9N3]
Exterior:
2004 Poloni TDI Sportline
Ex 2006 1.4 Corsa utility
Ex 1995 Nissan Sabre 200GXI
Re: Polo 9N Info and DIY guides
Exterior Lighting:
Polo 9N3 Head Light Bulb Changing Guide:
http://www.vwwatercooled.org.au/newforu ... hp?t=10756
Polo 9N3 Rear Tail Light Removal. http://www.vwwatercooled.org.au/newforu ... hp?t=10883
9N3 Light Globes list http://www.vwwatercooled.org.au/newforu ... php?t=9442
HID Disscusion
http://www.vwwatercooled.org.au/newforu ... hp?t=11941
9N-Fitting Front Fog Lights
Fitting 9N3 rear lights on 9N Polo's http://www.tigerstyle.co.uk/phpBB3/view ... 10&t=32532
http://74.125.91.132/translate_c?hl=en& ... KeK-T5vOAQ
How to Remove Front Fog Lights
http://www.vwclub.co.za/phpbb3/viewtopi ... ll#p788345
HID Disscusion
Interior:
Trim Removal
http://www.vwwatercooled.org.au/newforu ... php?t=8102
Polo Stereo Info http://www.vwwatercooled.org.au/newforu ... php?t=5808
http://www.vwwatercooled.org.au/newforu ... php?t=2929
Polo Tool Kit Reassembly http://www.vwwatercooled.org.au/newforu ... php?t=6897
Polo 9N Pollen Filter Clean / Change.
http://www.vwwatercooled.org.au/newforu ... hp?t=10755
Removing Rear Panels (3 Door)
http://www.motorbooks.co.za/details.php ... cd1e98a8a2
Install Audi TT pedals
http://74.125.91.132/translate_c?hl=en& ... F3Al1AR7Bg
Trim Removal
Interior Lighting:
Suspension :
DIY - 9n3 Forge Strut Brace Install http://www.vwwatercooled.org.au/newforu ... php?t=8849
How To Fit The Whiteline Rear Sway Bar
http://www.vwwatercooled.org.au/newforu ... r+sway+bar
Polo Suspension http://www.vwwatercooled.org.au/newforu ... php?t=1396
Drivetrain :
Power Steering fluid location. http://www.vwwatercooled.org.au/newforu ... hp?t=11075
APR Dog Bone Mount http://www.vwwatercooled.org.au/newforu ... php?t=9842
LSD Options.
http://www.vwwatercooled.org.au/newforu ... hp?t=12607
VW Key disassembly
http://www.riskin.org/vwkey
Suspension :
Drivetrain :
LSD Options.
VW Key disassembly
Brakes:
Standered brake pad options:
http://www.vwwatercooled.org.au/newforu ... ostcount=6
http://www.vwwatercooled.org.au/newforu ... #post44153
R32 334mm upgrade http://www.vwwatercooled.org.au/newforu ... php?t=6745&
Audi S3/TT 312mm Brake Upgrade http://www.vwwatercooled.org.au/newforu ... php?t=2648&
DBA 312mm Rotors worth it or not
http://www.vwwatercooled.org.au/newforu ... php?t=7322
Idiots Guide to Chipping
http://www.vwwatercooled.org.au/newforu ... php?t=6029
Transmission :
What's a good rpm to shift to save fuel? http://www.vwwatercooled.org.au/newforu ... php?t=3063
Have you had gearbox problems with your Polo GTI?
http://www.vwwatercooled.org.au/newforu ... php?t=8246
MotorBooks
Transmission :
MotorBooks
Wheels and Tyres:
Tyre Discution http://www.vwwatercooled.org.au/newforu ... hp?t=11047
http://www.vwwatercooled.org.au/newforu ... hp?t=11939
Removing Rear Wheel http://www.vwwatercooled.org.au/newforu ... php?t=7486
DIY Wheel Refurb
http://www.vwwatercooled.org.au/newforu ... php?t=8860
Intake and Exhaust:
Seat Air Intake Installation http://www.vwwatercooled.org.au/newforu ... php?t=6160
Seat Air intake test. http://www.vwwatercooled.org.au/newforu ... eat+intake
Forge TIP Discusion hhttp://www.vwwatercooled.org.au/newforum/uploa ... =Forge+TIP
What gains are to be made with an exhaust system? http://www.vwwatercooled.org.au/newforu ... light=pipe
DIY Wheel Refurb
Intake and Exhaust:
Nice post!!
I managed to break a clip when changing my grill eish!
Engine:
-1.8T
Noise When First Opening The Car Door. http://www.vwwatercooled.org.au/newforu ... hp?t=20212
Turbo Bolt Problem
http://www.vwwatercooled.org.au/newforu ... hp?t=10059
http://www.vwwatercooled.org.au/newforu ... hp?t=10584
Polo GTI - Do you have to use 98 RON?
http://www.vwwatercooled.org.au/newforu ... php?t=3172
Fuel Consumption ?
http://www.vwwatercooled.org.au/newforu ... php?t=2894
Engine Oil ?
http://www.vwwatercooled.org.au/newforu ... php?t=2506
Boost Gauge Wiring http://www.vwwatercooled.org.au/newforu ... hp?t=11273
Polo 9N (1.4 16v) Engine Air Filter Replacement Guide
http://www.tigerstyle.co.uk/phpBB3/view ... d4c7dd85eb
9N Strut Brace Fitting
http://drh87.tripod.com/Polo/9n_Strut_Brace_Fitting.pdf
Optimizing airflow to intercooler (96kw Polo TDI only)
http://74.125.91.132/translate_c?hl=en& ... n5ZRVHCtmQ
-1.8T
Turbo Bolt Problem
Fuel Consumption ?
Engine Oil ?
[General.]
Polo The Story. Everything you ever wanted to know. http://www.vwwatercooled.org.au/newforu ... hp?t=11273
Acceptable Delivery Kilometres ?
http://www.vwwatercooled.org.au/newforu ... php?t=4373
How many KM's do you run your car in for ? http://www.vwwatercooled.org.au/newforu ... php?t=4325
http://www.vwwatercooled.org.au/newforu ... php?t=4177
- Membership No: 731
Hey man.
Alright if I move this to FAQ?
Stuart
2006 Jeep Wrangler "Sarge"
1966 Splitty.
2014 KTM 1190 Adventure
No Mk1 ;(
"We've all been raised on television to believe that one day we'd all be millionaires, and movie gods, and rock stars. But we won't. And we're slowly learning that fact. So we build VDubs son..."
"Owning a MK1 varies between having sex to getting hit in the balls. Usually several times in one day."
1966 Splitty.
No Mk1 ;(
- Neuk
- Treasurer
- Membership No: 806
Nice work tyron
Do itRoadHaWg wrote:Hey man.
[quote="Neuk"]Nice work tyron
schweet thanks
schweet thanks
- mzuvele
- Car Model: 2015 Polo GTI 1.8TSI Manual
What a post man.........well done! Can't get any better than this for us who visit the forum daily!
My current car: 2015 VW Polo GTI 1.8TSI Manual
Wifes car: 2013 VW Polo 1.4 comfortline
Ex ride: 2012 Chevrolet Utility 1.4 base (Sold)
Ex ride: 2005 VW Polo 1.6 Comfortline (74kw) (sold)
Ex ride: 2004 Nissan 1400 Std (47kw) (Written off)
Ex ride: 2005 VW Chicco 1.4 (54kw) (Sold)
Ex ride: 2002 Toyota Tazz (55kw) (Sold)
- Le Clue
- Membership No: 1458
Why did I only find this topic now....awesome!
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
- Neuk
- Treasurer
Dammit - Forgot to move this to FAQ...Le Clue wrote:Why did I only find this topic now....awesome!
Cheers
Nic
Awesome stuff!
- Le Clue
The trim removal link does not have pics any more....does anyone have the pics?
Previous Rides:
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
- MeanTdi
- The Imposer Mod-whore-rator
- Car Make: Subaru
- Car Model: WRX
- Membership No: 1153
You will find some pics in this link:Le Clue wrote:The trim removal link does not have pics any more....does anyone have the pics?
http://www.taligentx.com/passat/mainten ... mechanism/
I used them to fix my driver door handle:
http://www.vwclub.co.za/phpbb3/viewtopi ... =3&t=99752
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Current: Subaru WRX
Ex: VW Golf VR6
