MK4 Mods thread!
- Car Make: No Cage
- Car Model: Only 2 Wheels
MK4 Mods thread!
Hi!
Post all your links/info/pics on MK4 mods here!
The lower you go, the more you break.
- Car Make: No Cage
Boost gauge mod
This is a neat trick this oke did! Must be a tuff job to do...
The guy took a digital boost gauge (auto meter R395 from autostyle) took it apart and installed it in the rev counter side of the clocks!
Its a worthwhile conversion and it has a clean look!
- Car Make: No Cage
Part numbers
- Car Make: No Cage
Where was your VW made?
Here is a link to site that gives you info on how to determine where your car was made ect ect ect...
http://www.autohausaz.com/vw-auto-parts ... mbers.html
- Car Make: No Cage
Soft touch rubber
Is the soft touch rubber pealing off on the interior???
The safest way to remove it is to use a soft rag and some 70% rubbing alcohol! Avalible from any pharmacy for about R10!
Please note: Do not use a sharp object to scrape as it may look like its working but when the alcohol dries marks will become visible!
- Car Make: No Cage
MK5 wipers for your MK4
Goldwagen now stocks the blade type wiper to fit your MK4! Looks good and works alot better than the normal type plus you get a clean euro look!
R225 gets you a set!
I orderd a set and will post the part number soon!
- VAG Cafe
- Registered for: 19 years 3 months
- Car Model: RS3
- Membership No: 675
- Car Make: No Cage
- Car Make: No Cage
Overseas tuning shops
ECS tuning
GTI click here
2.0L click here
TDI click here
Awesome GTI
click here
TM tuning
click here
C&R enterprises
click here
Big Boys Toys UK
click here
GTI click here
2.0L click here
TDI click here
Awesome GTI
click here
TM tuning
click here
C&R enterprises
click here
Big Boys Toys UK
click here
- Registered for: 20 years
- Membership No: 731
ECS Tuning just need to sort out their shipping. The parts cost less than the shipping!!!
Stuart
2006 Jeep Wrangler "Sarge"
1966 Splitty.
2014 KTM 1190 Adventure
No Mk1 ;(
"We've all been raised on television to believe that one day we'd all be millionaires, and movie gods, and rock stars. But we won't. And we're slowly learning that fact. So we build VDubs son..."
"Owning a MK1 varies between having sex to getting hit in the balls. Usually several times in one day."
1966 Splitty.
No Mk1 ;(
Re: MK5 wipers for your MK4
Is this an Aero wiper conversion? What's the part number?MK4 GTI 20VT wrote:Goldwagen now stocks the blade type wiper to fit your MK4! Looks good and works alot better than the normal type plus you get a clean euro look!
Thanks for the thread boet
- Car Model: 2010 Scirocco 2.0 TSI
- Membership No: 1079
- Fanatix
Re: Soft touch rubber
Thanx man ... Have you tried itMK4 GTI 20VT wrote:Is the soft touch rubber pealing off on the interior???
______________________________________
Golf IV GTi:R
Jetta IV TDi
Golf IV GTi:R
Jetta IV TDi
- Fanatix
- BillyBob
- Car Make: BMW
- Car Model: E90 330d M-sport
Re: Boost gauge mod
OMG - that is SO trick...MK4 GTI 20VT wrote:This is a neat trick this oke did! Must be a tuff job to do...
Anyone tried this or found a how-to?
Sometimes, we need to remind ourselves of the simplicities of life - you only need two tools: Duct tape and WD-40. If doesn't move and it should - use the WD-40. If it shouldn't move and does - use the duct tape.
- Car Make: No Cage
Sorry for the late reply! Forgot about this threadGTiManiac wrote:Is this an Aero wiper conversion? What's the part number?MK4 GTI 20VT wrote:Goldwagen now stocks the blade type wiper to fit your MK4! Looks good and works alot better than the normal type plus you get a clean euro look!
Well the guys from GW was talking crap about the direct replacment aero wipers for the mk4, you only get that oversized piece of plastic that you clip onto the wiper arm and a universal aero type blade clips onto. Looks utter crap IMHO.
What I did was this: (no pics, sorry)
Bought a set of wiper arms of a pre-face lift polo, took these and removed the piece that the blade fits on, you will see that its bent around the wiper arm. Its a biatch to remove! Once you bent it open and got it of do the same with your stock wiper arms. You have to use some pratly steel to make sure the aero wiper fittings stick to the stock arms!
Then go get yourself some polo wiper and then its done! It is a big job to do but it looks 10timer beter than the stock blades!
If you want to see a pic of the aero wipers, go to my rides theard, My 02' MK4 GTI!
Cheers
- Car Make: No Cage
Yes I did try it out but didnt get far cos my dog bumped the alcohol over and didnt get a chance to get more and finish the whole interoir.Fanatix wrote:Thanx man ... Have you tried itMK4 GTI 20VT wrote:Is the soft touch rubber pealing off on the interior???
It does work but you must have a bit of time on your hands cos it does take long to get it perfectly clean! Looks awesome when its done!!!
Going to try to finish the rest of it asap!
- Car Make: No Cage
Re: Boost gauge mod
If you can sponser me a gauge ill do a how-to just for youBillyBob wrote:OMG - that is SO trick...MK4 GTI 20VT wrote:This is a neat trick this oke did! Must be a tuff job to do...
