DIY - Bulb replacement
Voden
Car Model: Polo 9N3
Post by Voden »
Ahoy guys,
I'm looking at changing all my bulbs (park, drive, brights) in the headlight from stock to LED.
These are the bulbs I'm looking to replace my drive lights with. Bulb
Im a bit lost with the LED headlight as it has dims and brights so what I want to know is, if I use these bulbs will my brights still be accessed via the indicator leaver? and will it matter if I take the original brights out?
Any help or just general information on how the lights work on a car will be appreciated.
G-spot
Car Model: Audi S3 Sedan
Membership No: 1215
Re: DIY - Bulb replacement
Post by G-spot »
First off changing your main head lights to LED's might not be the best idea IMO
Even though they might be a high lux bulb generally range on LED lights are pretty poor. So you might end up with lower visibility than stock halogen lights
If you want to change the head lights rather look into HID's
(I'm assuming you have a polo 9n3 as per your info) The main light and the brights work on 2 different circuits and 2 separate bulbs, so not sure how a duel bulb would work
The light housing is also different to reflect the light in 2 different ways.
Rather look at HID's for the high/low beams (although with HID's you rarely use the high beam/brights) and go with LED for the parks
Grant Hendry
Membership no.:1215
2016 Audi S3 Sedan
1978 VW Golf 1100 GL
2012 VW Golf GTI Edition 35
2007 VW Golf GTI
2006 Polo 1.9 TDI Sportline
2012 VW Polo GTI
Kavi4GP
Car Make: Toyota
Car Model: Corolla D4-D
Membership No: 2016
Post by Kavi4GP »
G-spot wrote:First off changing your main head lights to LED's might not be the best idea IMO
HID in stock unit is just as effective as LED , not better really than high performance bulbs , both cant direct light properly and you end up with glare and diminished light distance.
2013 A3 1.6 TDi S-Tronic 8V.1
2013 Ford Focus 2.0 Sport
2011 Hyundai i20 1.4
2006 Toyota RunX
