Golf 6 RNS510 unit battery drain issue fix
Wild VDUB
Post by Wild VDUB »
Howzit guys. The battery on my golf 5 2.0 is always going down. The battery can't be at fault cause I changed it about a year back. The only thing I did recently was put a golf 6 gti MP3 player on the car but I'm not sure whether after that then the battery started going down. Any clue what's wrong guys?
TIA
MK2 G60
Membership No: 388
Re: battery draining
Post by MK2 G60 »
The golf 6 radios will draw the battery if you dont code the car for it or have the correct gate way installed.Remove the radio and check it again.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
Post by ruan9n »
You need to do the following.... I did this fix on my car and the battery is 100% fine. I also have a rcd310 the newer spec mp3 vw radio.
Used this technique to have a small harness made up to cope with the issue explained below...
"I have an easy not techinical solution for those of you that has a RNS510 unit and have the battery drain issue. So if you do not want to go through the hassle of finding a new canbus and recoding your canbus for your car try the method below. I have been using this method for over a year now with not problems at all."
Step 1:
Step 2:
Step 3:
Step 4:
MarshallGTi
Car Model: Ibiza 1.9TDi FR
Membership No: 1665
Post by MarshallGTi »
does ur car having a tracking device?
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Post by ruan9n »
Wouldn't be the tracking device. The golf 6 radios draw more power from the battery than mk5 ones would, even with the car switched off it draws power. You can either do this fix or buy a new CANbus unit from vw or a scrapyard and have it coded via vcds.
Wild VDUB
Post by Wild VDUB »
Thanks for the help guys. Will try that fix tonight
emd20v
Car Model: A3 Sportback 2.0T
Post by emd20v »
will this blow anything? if its connected incorrectly?
MeanTdi
The Imposer Mod-whore-rator
Car Make: Subaru
Car Model: WRX
Membership No: 1153
Re: Golf 6 RNS510 unit battery drain issue fix
Post by MeanTdi »
Golf 6 RNS510 unit battery drain issue fix & DIY fix.
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Sinbad
Car Make: Mercedes
Car Model: R170 AMG Hairdryer
Membership No: 1152
Post by Sinbad »
There's an even neater way IMHO.
It would be neater to open the fuse box and move the radio fuse terminal to a switched slot.
Just move the radio fuse - open the box, remove the wire/plug from where it is, to the switched area. Then plug the fuse in normally.
