Can anyone help please , Have a 1.4i velocity engine . The engine was running fine until i installed the time engine in new body with the same wiring , but know it revs on its own , without pressing the accelerator . I check the cable its fine.Can anyone help please?
Mp 9 golf 1 revs on its own
Re: Mp 9 golf 1 revs on its own
Check for vacuum leaks on intake an booster vacuum pipe.
Thanks I will doPapaJo wrote:Check for vacuum leaks on intake an booster vacuum pipe.
- Car Make: ShitiGolf + CRX
you might need to do throttlebody calibration on VCDS (probably)
- Car Model: MK5 GTI
Hi I have the same problem any advice or where in cpt to go etc
- ob wan
- Car Model: MK1 2.0 16vT
problem sorted? if not, what do you mean it revs on it's own, is it up and down at idle or does it just stay high?
05 G5 Gti (ex)
97 LSvtec (ex)
05 Ford Ranger 4.0 V6
Mk1 velo 2.0 16v...Turbo
97 LSvtec (ex)
- Registered for: 3 years 7 months
Hi guys, Im new here Im having the same problem with my 2009 citirox 1.4i. Had it on the computer and it said O2 sensor no signal
Replaced it. Car Idles ok but as soon as you rev it it stay high. Oh amd the previous owner "cleaned" the throttle body and said after that the car started doing it. Any idea what else I can look at ?
