Retrofit PDC to golf VI
Belix
Car Model: Passat B8, Jetta CLX MK2
Post by Belix »
OK this one has been a long time coming. Frankly I don't get much time for this any-more.
Anyway, basically, a long time back when I was young, I decided to buy the kufatec PDC retrofit kit. Seems like a good idea at the time...anyway...
So kit consists of PDC module, several wiring harness, 8 unpainted PDC sensors and some extremely vague German instruction for a left hand drive car. Note left hand drive...I suspect that will come back to bite me in the ass...
So idea is, remove rear bumper, drill holes for sensors, fit PDC sensors, run wiring to front of car, remove fornt bumper, drill, fit sensors, fit PDC module, link up wires, program, bob's your uncle.
Well no.
removing the trim to lay the wiring to the rear bumper is no simple feat. Many of the panels have hidden catches ans screws etc, and to remove one panel, yuo need to take out a bunch. Most of it can be seen in my RVC retrofit, but I'll add photo's as I find them.
Since I had to replace the rear bumper anyway, I just got one with the PDC hoels already drilled, so that part was at least easy.
I have no got gatvol of having my car in bits, so want to try and finish the *(&(*&( project.
The German instructions say to mount the PDC module in a small access port under the windscreen wiper motor.
Yes.
First issue is to try and remove the windscreen wipers. Remove the cap, put wipers in service position, remove nut, fold wipers up and wiggle about until they come loose. Well driver's wiper came loose easy enough. But passenger side not. I eventually had to drive round to Morne, who took exactly 2 seconds to wiggle it again and get it loose. :crazy:
Then remove all the trim around either side of the wiper tray, the rubber seal, and the wiper tray cover.
Then to remove the wiper motor. This can be a bit of a pig. Remove the two large hex bolts in the rubber grommets,
and the bolts for the centre wiper support. Then if aligned right and if moved correctly, it will move out. Takes some trying.
After the wiper linkages have been cleared, I have access to the inspection hatch.
Well according to the German instruction, you mount the PDC module here. Except that I can see nothing to mount it on.
This is what is under the panel
And this is the module
SO how to secure it?? Maybe there is a bracket missing or something?? :bang:
Belix
Re: Retrofit PDC to golf VI
Post by Belix »
Can anyone confirm:
- The pin on the CECM that provides power to the dash button lights?
- Where the best place to link into CAN high and CAN low is? I think the module with the red plug in the second last picture in the CANBUS module and I think I can tap in there, but not something you want to get wrong!
Belix
Post by Belix »
Have not found much info but I'm fairly confident the module in the seocnd last picture in the canbus moduel where I can pull Canhigh and can low from. Nothing like playing with the canbus module to get you walking to work.
The kufatec instructions showed it in another location...it's where the PDC module should be so I guess in a way it's lucky, otherwise I'd not know where to look for it.
Since everyone is looking at me blankly about where to pull power for the interior PDC button illumination from of the CECM, I think I'm just going to pull it from one of the adjacent buttons...hopefully they have the same pins...
As for securing the PDC module, unless I can come up with some custom bracket, I guess I'm forced to wrap it in some foam and stash it near the canbus module.
Still got no idea how to get the front sensor wires through the firewall. At this stage, I'm happy just to see the back sensors working.
Belix
Post by Belix »
Though perhaps the PDC module goes behind canbus module, so got it out, but definately no space for it there either. THink I must just wrap it in foam and put in to the right of the canbus.
since I hate cutting into the original wiring harness, I got a four pin quad lock connector and made a small splitter harness
Then disconnect can high and can low (pin 6 and 16) from the canbus plug, whire it through the new mini wiring splitter, add terminals to the wiring provided for the PDC module and bobs your uncle
Then connected up the plugs, battery and VCDS. Module located so got the canbus wires right at least! However, VCDS would not let me code for "illustration" of pdc on the RNS, kept giving out of range errors! Ended leaving that unticked.
Long story short, turns out you need to have everything plugged in (even the sounder speakers) to be able to code the module. Also it goes wonky unless it gets power only on ignition, so don't use permanent power.
With coding done, got car in reverse and presto, it all works! unfortunately the front sensors are in the passenger foot well still, so the front sensor screached unceasingly.
Unplugged everything again until:
- I can get wiring through firewall,
- sensors in front bumper
- secure PDC module and front sounder somewhere
- connect up pdc button illumination.
Belix
Post by Belix »
seems carsystems offers the park pilot retrofit, but still don't know anyone who has done it, so a bit of a gamble...hmmm
http://www.carsystems.pl/vw-golf-mk6-5k ... id375.html
For laying wiring to the rear bumper, check the DIY for the RVC - should all be there.
http://www.vwclub.co.za/phpbb3/viewtopi ... 0#p1171700
Now to get the wiring for the front done...
rodga
Nazi Spelling Master
Car Model: MKVI GTI
Membership No: 1323
Post by rodga »
Seem to have missed this thread
Hope u come right
Sent from my LG-P970 using Tapatalk 2
rodga's ride
'09 Generic XOR 125 - matte black - Daily Driver :)
Belix
Post by Belix »
Sorry for the no pics - camera mem card decided to bum out ... again...
Did not need to drill the bumper for the sensors in the end, as I got a new front and rear bumper, so when I did I just ordered the PDC version. However there are quite a few topics on various threads about drilling the holes. Use some tape to help prevent the paint tearing around the edges and go slow. Best advice would be to get an old scrap bumper from a scrapyard and practice before hand, not something you want to mess up!
I have 8 of the brackets and mounting pads needed for the retrofit if anyone can use them , let me know.
I then extended the wiring harness to go through the grommet in the firewall just behind the battery since the kit seems to be made for LHD and it was too short. In the engine bay, I followed the fog light wiring down to the bumper; and inside, tucked the wiring behind the carpet in the passenger foot well, behind the console (beware the hot aircon pipes!) and behind the carpet under the left footrest to keep it neat.
Since the given location in the German instructions for the button illumination does not exist, or at least has a completely different pin, I checked the other two console switches with a multimeter to check which one gave power with the lights on AUTO and no power when off. Turns out PIN 1 on the ESP button and TPMS is for the button illumination power, but weirdly it goes to PIN 3 on the PDC switch...so check before hand!
Putting in the console button is pretty straight forward. Use a trim tool or credit card to pull out the gearlever surround. Under there are two obvious screws that will release the ashtray section with the console switches. To make access easier, I also removed the two side panels on either side of the console to facilitate laying the wiring.
Add some other cheezy buttons if you want :crazy: :crazy:
Now I just have to connect the power up to live-on-ignition (NOT permanent power), job for tomorrow.
Shaddow
Car Model: Audi TT-S
Membership No: 1957
Post by Shaddow »
Awesome job! Well done and thanks for sharing! :)
Love that eject button! Hahaha.... :)
2012 Scirocco DSG K04
CPi Tuned!
12.3@184 - Tuner Wars (Nov 2014)
245wkw 564Nm
2008 Audi TTS S-Tronic - Revo 2, DP (12.9 @ 178 - Tarlton S2S)
2008 Golf 5 GTI DSG - K04 APR Tuned (13.6 @ 175, street tyres - Tarlton S2S)
Belix
Post by Belix »
useful link for adding wired to the fusebox
http://www.my-gti.com/601/addition-of-e ... t-fuse-box
I got a crimper from RS online.
To remove the lower trim for the mk6, I had to remove the two screws holding in the instrument panel and carefully slide it forward. This let me access the last hidden screw holding the lower panel on.
And a link to some of the common fuse locations
http://www.golfgtiforum.co.uk/index.php?topic=200792.0
