Another E92 325i
MMS Auto is a small privately owned and operated Motor vehicle workshop that specializes in Quality services and exceptional maintenance at affordable prices.
Rascal69
Registered for: 16 years
Car Model: MK1
Membership No: 1490
Another E92 325i
Post by Rascal69 »
This car was recently purchased privately with 135k on the clock and full franchise history.
Customer contacted us to address the the following:
1. Major Service : Air filter , oil Filter, Oil, plugs.
2. Full inspection: he wanted to know everything that needed attention.
3. Idle was lower than normal causing a dip at low revs and a small shudder
So we booked it in for some TLC and got to work
All original parts where supplied
We start out with scanning for stores errors
Then we ran the vanos adaptations and set the idle using the factory software and technical instructions
Now to start with the service:
Old vs new air filter
New plugs
Check the old plugs - 2 NGK and 4 Bosch plugs fitted by agents!!
Used a tiny bit of silicone paste so allow the coils to be refitted easily
Drained oil
Swapped out orings on the OFH
New oil filter fitted
New oil filled
Replaced cabin filter
All done Image
We also did the full inspection and advised the customer that he would need to address the following :
1. Flush and bleed brakes - brake fluid is old and burnt
2. Flush and bleed power steering - fluid level is low as well fluid is old and burnt.
3. Flush and bleed cooling system - cooling system is full of tap water.
Things like brakes , suspension, prop coupling.ect were all still fine and didn’t need any attention.
Current: 2007 ///M Coupe
Current: 2019 Fortuner 4x4
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Yakuza Racer
Voora Molester
Registered for: 13 years 8 months
Re: Another E92 325i
Post by Yakuza Racer »
This makes me uncomfortable that agents work so k@k considering i parted with enough money to buy a small car with them recently lol
Thupercharged S4
Rascal69
Car Model: MK1
Membership No: 1490
Another E92 325i
Post by Rascal69 »
And then they were back for round 2
This time the fluids needed to be flushed and bled.
Get the car up, wheels off and we start.
Drain the radiator
Mixing Distilled water and Coolant
Filled up with Coolant mix
Power steering was so low, it barley showed on the level indicator
So we removed the old fluid, flushed it twice and bled it . Steering felt so much softer after this
Lastly we flush the brake fluid reservoir 3 times and then fill up with new fluid
Flush the brake lines and bleed
And lastly we bleed the ABS pump using the laptop and bmw factory diagnostics
All done, the car was collected and the owner was very happy.
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
PöLö1.4...
Car Model: Polo Playa
Post by PöLö1.4... »
Enjoy reading all the posts thus far :hurray:
Did the adaption resolve the " Idle was lower than normal causing a dip at low revs and a small shudder" issue?
Rascal69
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
PöLö1.4... wrote: Thu Sep 19, 2019 9:41 am Enjoy reading all the posts thus far :hurray:
Thanks bud, The adaptations reset the vanos solenoids and the ilde reset procedure sorted out the dip and shudder...
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
kevi kev
Registered for: 13 years 7 months
Car Model: A3 2.0 Sportback & A5 Coupe
Post by kevi kev »
Sorry for the hijack, can you please DM me a price for a brake fluid flush for a 2013 Audi A5 2.0T
VAG Fan
Post by VAG Fan »
Ditto, very enjoyable reads.
Question:
Could you comment on the "tap water" issue? How do you actually notice that there is tap water in the cooling system?
I ask this because I've been motoring for 30 years and have always used tap water to mix my coolant, and provided that the correct ratio was maintained, I've never had any problems with corrosion or premature failure of components.
Rascal69
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
VAG Fan wrote: Thu Sep 19, 2019 12:10 pm Ditto, very enjoyable reads.
Question:
I dipped a paper towel into the coolant reservoir and when i pulled it out i noticed it had no colour to it.. Coolant from bmw has the Blue Dye and Vw's have the pink dye in it... also the bottle cap was almost seized on and when we got it off, you could see all the chlorine stains... I personally dont use tap water in my own cars, its just habbit, as i have seen so many cars with corrosion and discolored water bottles.ect
The one car i'm busy doing head gasket on now, customer filled water previously... when the gasket blew and the cylinder filled up with water, it corroded the cylinders, water channels.,ect... a simple thing like coolant and distilled water would have stopped this...
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
VAG Fan
Post by VAG Fan »
Ah, OK, if they only added tap water and no coolant additive, then that's entirely a different story. The previous owner of my Fox also did that, and by the time I got the car, it had caused a lot of rust, and although I did a flush, the head gasket failed soon after (because some of the holes were blocked with rust flakes).
It's no criticism, to the contrary, I'm sure you're sticking to best practice. I was only wondering if the coolant really cares whether you dilute it with distilled or tap water. My coolant remains pink and clear for years, even though I dilute it with tap water.
Rascal69
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
VAG Fan wrote: Thu Sep 19, 2019 12:47 pm Ah, OK, if they only added tap water and no coolant additive, then that's entirely a different story. The previous owner of my Fox also did that, and by the time I got the car, it had caused a lot of rust, and although I did a flush, the head gasket failed soon after (because some of the holes were blocked with rust flakes).
No worries Mr, i understand and we all learning so dont feel shy... Since i'm working on other peoples vehicles, i have to treat it like my own as to avoid any unnecessary issues... So as i would do for my own, i do for the customers...
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Rascal69
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
Had this car come back over the weekend for the following work:
Front shocks and mounting replacement
Rear brake discs, pads and sensor
The parts that were supplied
Got the car up on the lift and started with the brakes
Cooper Anti seize used
New pads
New brakes fitted
Old parts packed for customer
Removed the front shocks for replacement
Old mount had seen better days
Shocks were finished so the car was riding on the bump stops
Fitted new shocks and mounts
Loaded the old parts in the boot for customer
Ready for collection
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Car Make: Fiat, Toyota, Mazda
Car Model: Uno, Auris, CX-5
Post by Unobeat »
Outstanding work on this car, wow.
Car must be driving like new after all the work carried out.
Post by Unobeat »
Rascal69 wrote: Thu Sep 19, 2019 12:26 pm
Question:
Very informative detailed info. :thumbup:
Rascal69
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
So Wayne got in touch with me last week and wanted to come drop of his bosses 325i for some work.
He always sources his parts directly from Delarey and arrived to drop off the car on Saturday morning, along with new front discs , pads , brake sensor , new boot lid struts. the instruction was brakes are squeaky and very annoying please replace it and off he went.
And we start, get it on the lift
Strip the brake discs, pads and bracket.
Cleaned the rust and dust off the hubs.
Also cleaned the pins and lubricated them
Cleaned the contact surfaces of the bracket where the pads sit and slide on.
Cleaned the machine oil off the new discs before installing
Copper anti seize paste on hubs before fitting discs.
Brake caliper piston contact surface cleaned and prepped with copper anti seize
Bracket also cleaned and prepped with anti seize paste
Preparing brake pads with anti squeal spray
Now that everything was cleaned and prepped for install. I also kept an eye out on the awesome rugby World Cup. Image which made this job take a few hours but no one was complaining .
Once the game ended I continued with the install of the new brakes.
Installed the discs on the prepped hub.
Replaced the sensor as well
All done to perfection
Check and make sure brake fluid level is correct
While I was checking the brake fluid level I saw the engine water drains were blocked with leaves and twigs so I cleaned them out and refit it.
Ran diagnostics and reset the counter for front brakes
Cleared a dsc error
Replaced the boot struts
And called Wayne to collect. Image
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
