7 Things you need to know about the VW Golf 7 GTI
Car Make: VW, Mini, Slowyota
Membership No: 3337
Post by kingr »
Here's our VW Golf Mk7 Gti buying advice to help you make an informed decision when considering buying this car.
Watch Video
Shop used VW Golf 7 Gti's for sale in South Africa https://www.wheelindex.co.za/cars-forsale/VOLKSWAGEN/VW_Golf_7
Top 7 issues with the VW Golf 7 GTI
#1 - Waterpump / Thermostat leak
#2 - Timing chain wear (stretch)
#3 - Cylinder head valve springs
#4 - Fuel Injectors carbon build-up
#5 - High Pressure Fuel Pump (HPFP)
#6 - Interior one-touch buttons cause windows not go up or down
#7 - Front shocks top mounts
Disclaimer: This is a buyers guide only. Any problem with a sale car should be diagnosed by a competent and professional technician. All information provided is for information only and is not designed to replace a service manual or professional help. Use at your own risk.
Kurt #3337
- 10" Mx5 NC2 (main daily)
- 80" VW Mk1 2 Door Golf 8vt project 192wkw/314nm
THANAS
Car Model: AW Polo GTi
Membership No: 2035
Re: 7 Things you need to know about the VW Golf 7 GTI
Post by THANAS »
#1 - Definitely;
#2 - Not really a specific problem, affects most chain driven, modern engines;
#3 - More rocker arm failure, but not a common issue;
#4 - Not as bad as the 5/6 but still a problem despite the local 7s having port injection active at idle and light cruise;
#5 - Not a common issue at all;
#6 - Definitely;
#7 - Definitely again;
and
#8 - Ringland failure / LSPI, again, not as badly affected as say the EA888.2 1.8T, but a present issue nonetheless, high comp TGDI motors are all potentially susceptible, especially since the API SN+ grade oils are not widely available yet. It it needs to be taken into account when modifying, and when approaching how the car is driven (lugging etc).
Membership No: 3337
Post by kingr »
Noted on #8. Never knew that was an issue.
Regarding #2, the reason why we mention this is because a timing should actually last much longer on a car than what the VAG chains do and many other makes don't have the issues of timing chain stretch/wear. BMW for one has many problems with their high-performance engines, but not with timing chains/tensioners. Like on the BMW N54 twin-turbo engine the timing chain is not one of the many issues that can be present with that engine.
Overall the G7 GTI is solid car performance car, I would highly recommend it. This is more of a "watch out for these and don't be ignorant".
THANAS wrote: Fri Nov 22, 2019 3:45 pm #1 - Definitely;
#6 - Definitely;
and
Kurt #3337
