On my dashboard abs light is on, steering wheel light is on and EPC light is on. Brake light is flashing. Now when drivi
oos
Registered for: 3 years 3 months
Car Model: Vivo 1.4
Post by oos »
On my dashboard abs light is on, steering wheel light is on and EPC light is on. Brake light is flashing. Now when driving the km do count.
Can plz anyone help me.
I can't even find my brake switch.
oos
Car Model: Vivo 1.4
Re: On my dashboard abs light is on, steering wheel light is on and EPC light is on. Brake light is flashing. Now when d
Post by oos »
I recently did service
Callum229
Post by Callum229 »
That sounds like no communication to the modules, an electrical fault, faulty wiring, canbus error, etc.
Get the car scanned for trouble codes, check all grounds, wiring and plugs for corrosion and if they are all seated properly.
Maybe you unplugged or damaged the wiring to the modules somehow when servicing.
What was done on the service? Sometimes a low battery can also trigger those faults, is it cranking and firing up fine?
DieterMK5
Registered for: 10 years 2 months
Car Model: Jetta MK5 1.9 TDi
Membership No: 3015
Post by DieterMK5 »
Topic moved to the correct section.
oos
Car Model: Vivo 1.4
Post by oos »
DieterMK5 wrote: Wed Jan 13, 2021 8:07 am Topic moved to the correct section.
Oil changed. Petrol filter. Plugs. Oil filter. Air filter.
oos
Car Model: Vivo 1.4
Post by oos »
Thanks i will check. The service was Oil. Petrol filter. Plugs. Oil filter. Air filter.
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
Apologies if I missed it, what car do you have? This sounds like a brake light switch and/or ABS sensor issue.
oos
Car Model: Vivo 1.4
Post by oos »
Neuk wrote: Wed Jan 13, 2021 2:19 pm Apologies if I missed it, what car do you have? This sounds like a brake light switch and/or ABS sensor issue.
Polo Vivo 2012 hatchback.
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
oos wrote: Wed Jan 13, 2021 4:31 pm
I suggest getting A VAGCom scan done to pick up any error codes and go from there. You could also check your cars earthing as VAG platform cars can develop weird issues due to faulty earthing.
oos
Car Model: Vivo 1.4
Post by oos »
Sorry for taking a long time to respond.
It appeared that the Fuse next to the battery is causing the problem. I place it and only thing was left was EPC. It started jacking. I cleaned the throttle and unplug and plug the throttle plug. I plugged the Back light switch but i am unable to place it back. The wires appear to be shot.
oos
Car Model: Vivo 1.4
Post by oos »
