Hi Guys
I am attempting to do a small sound install on a polo sedan 2015 model(not vivo model). I have a starsound powered sub which im attempting to install. Im looking for a ground spot in boot and closest i could find is seatbelt bolt. I want to find out what tool do i need to remove that bolt? I googled abit and see that it maybe a hex or spline bolt. Not too sure. I have standard tools like ratchet but not sure bolt to use.
Tool needed to remove seatbelt bolt
- Jetta2
- Car Make: VW, VW, Aprilia
- Membership No: 1087
Re: Tool needed to remove seatbelt bolt
They use spline bits.
You can buy kits of spline bits at Builders Warehouse or any decent car spares place. Or you can buy them as single bits.
Please, Don't ever use a seat belt bolt, its a safety critical item.Builder21 wrote:Hi Guys
Imagine your child, wife or your mother is using that belt and has to rely on it to survive, would you trust it with some copper wire squashed under it?
Look a little further like near the taillamps for a factory earth point, or make your own one with a nut and bolt somewhere on a non structural bit of metal.
- Registered for: 4 years
It was a M10 spline bit. Thanks will look for another ground spot.
Cool bro.Builder21 wrote:It was a M10 spline bit. Thanks will look for another ground spot.
- Belix
- Car Model: Passat B8
I know the bits as triple square. Is that a US thing? or are they similar but different bits?
I will post a picture of one tomorrow.Belix wrote:I know the bits as triple square. Is that a US thing? or are they similar but different bits?
- Belix
Thanks, they look like a triple square bits I know. Perhaps it's the shape of the points that are different.
