Radio model?
Mr.G24
Car Model: MK5 Jetta 1.9 TDi Comfortline
Radio model?
Post by Mr.G24 »
Hi Guys,who can tell me what model radio this is and will it be plug and play in my Jetta 5?
I want to purchase/swop this from a guy,but he said that it drains his car battery,cannot let car stand for longer than 12 hours before he needs to start to avoid no start due to battery power,i also don't want this to happen to my car battery,so how can this draining of battery be prevented should i think to purchase/swop the radio,i dont want to sit with those issues,i also saw that the radio is made in china,is this an aftermarket radio or OEM radio?will it also work on the steeringwheel controls?im thinking of swopping my RCD310 for this one,let me know pleaseImageImageImage
Sent from my SM-J415F using Tapatalk
2008 VW Jetta 1.9 TDI Comfortline (Reflex silver)
77kw @ 4000
250nm @ 1900
Car Make: VW, VW, Aprilia
Re: Radio model?
Post by Jetta2 »
According to the part number it is an RCD330.
And they all seem to have some sort of battery drain issue with cars with an older CANBUS version or something like that.
Google "RSC330 battery drain" and go read up on it.
mk2-phreak
Re: Radio model?
Post by mk2-phreak »
Read through the thread on RedditImage
Sent from my HD1901 using Tapatalk
Mr.G24
Re: Radio model?
Post by Mr.G24 »
Thanks for the feedback,
This seems to be a no no then for me,wil rather let this deal go,seeing that i have to change the canbus gateway and have to change the steeringwheels to a newer steeringwheel or change the canbus for the steering wheel controls to work.
I think i will rather still look at getting the RCD320 then,will this be a better option without battery drain and the works,hopefully that will just be plug and play and steering controls will work without any canbus upgrades,
Do you guys agree?
77kw @ 4000
250nm @ 1900
DieterMK5
Registered for: 10 years 2 months
Car Model: Jetta MK5 1.9 TDi
Membership No: 3015
Re: Radio model?
Post by DieterMK5 »
I have a 09 model and in need of a new radio. Please pass on the details for me? It would be appreciated
Mr.G24
Re: Radio model?
Post by Mr.G24 »
i have read the reddit article and with my jetta 5 model being a 2008 Model, do you guys think i will have the updated Canbus gateway? how will i be able to check if i do have the updated canbus gateway and will this RCD330 unit then work without the battery drain issue in my jetta and will the steering wheel controls also work?
77kw @ 4000
250nm @ 1900
mk2-phreak
Re: Radio model?
Mr.G24 wrote:i have read the reddit article and with my jetta 5 model being a 2008 Model, do you guys think i will have the updated Canbus gateway? how will i be able to check if i do have the updated canbus gateway and will this RCD330 unit then work without the battery drain issue in my jetta and will the steering wheel controls also work?
You will have to check part numbers
Mr.G24
Re: Radio model?
Post by Mr.G24 »
sorry for asking, but what part number do i have to check and where on my car will i see those part numbers?
77kw @ 4000
250nm @ 1900
Re: Radio model?
Post by Jetta2 »
I think you can check with VCDS, but not sure.
Mr.G24
Re: Radio model?
Post by Mr.G24 »
okay cool, but will i need to check the part number for the canbus gateway and what else do i need to check to make sure this unit will work on my 2008 model
77kw @ 4000
250nm @ 1900
Mr.G24
Re: Radio model?
Post by Mr.G24 »
also do you think it will work perfect on a 2009 model jetta 5, Dieter's car?
77kw @ 4000
250nm @ 1900
mk2-phreak
Re: Radio model?
My dude. My screenshot clearly shows what you need. Why are you not reading?
Mr.G24
Re: Radio model?
Post by Mr.G24 »
i did read, but i'm not to clued up with this, i have read through the screenshot again and now i see and make sense.
77kw @ 4000
250nm @ 1900
