1988 VW fox Clutch
- Registered for: 4 years
1988 VW fox Clutch
Bought a variant clutch kit ,while fitting the flywheel I found that one of the securing bolt holes on the Press late was stripped and the bolt can be pushed through the hole ,I did not even start to use any Tools,now the shop owner do not want to warrant his guarantee,he sy the bolt was overtorqued and stripped ,you can read about it in Hallow Peter, How can I fix the problem without getting a new Pressure plate ???
