Amp mystery (HELP)
- Registered for: 5 years
Amp mystery (HELP)
I have a 06 citi 1.4i with a system consisting of a:
Pioneer GM-D9605 5 channel 2000w, Rockford R16-S 160 Watt splits,
Rockford R169X3 Prime 6 x 9 3-Way, Rockford P2D4-8 Punch 8" P2 4-Ohm DVC sub,
Pioneer AVH-200EX double din.
Now the mystery is after a month or so the power/protect light would turn red and the subwoofer stops playing while the speakers continued to play. We then checked everything we could think of including grounding, rca's, all the wiring, altenator and the battery. Now the sound to the sub is completely gone. Sub was tested and also fine.
Any help or advice will be appreciated
Sent from my F5121 using Tapatalk
Re: Amp mystery (HELP)
Hi more than likely the channel for the amp is blown, I recommend taking it to a Rockford agent, they will send it into Rockford to get it repaired. I had the same problem and it cost me R450 with tranport
Sent from my SM-G965F using Tapatalk
Sorry only saw now it's a pioneer amp
I forgot to say that it played for about 2min before the sub would stop playing and the power/protect light would turn red.heidenrich wrote:Hi guys
I still think get the channel on the amp tested its probable blown
Where can i get it checked?
Where are you?
- jaredm
How did you wire the sub, in series or parallel? If it’s a dual 4 then you are either running it 8ohm or 2 ohm. Make sure the amp can handle the impedance you are using.
2015 Golf VII GTi Performance Pack DSG
Mk2 Golf 2.0l 16v Exec
2012 Edition 35 Dsg CPI Stg2
Golf 6 .:R DSG CPI Stg2+
Scirocco 2.0TSi DSG K04
Golf 3 VR6 Turbo
Golf V GTi DSG
Mazda 3 MPS
Golf 3 VR6 Turbo
Golf V GTi DSG
Mazda 3 MPS
Agree with jaredm.
I think the p2 is a dual 2ohm. How is it wired up?
U are probably overloading the amp. Can the amp not be bridged?
I live in Mosselbaai WC, the sub is wired in parallel.
Online
- Car Make: Ford
- Car Model: Focus ST
Wire it in series and see if that makes a difference.
2010 ST225 - 238kw 439nm
Will check that out and let you guys know
