Hi guys,
I want to install an amp cable from the engine bay to inside the car. I'm sure there is 100's of people that did this already but since it's my 1st time, I would appreciate some help as I would like to try this myself.
Is there a way to pull through the cable without having to make holes? The cable is only about 4mm thick.
Is there any pictures or videos you can share on how and where you ran your cable through.
Thanks in advance.
Polo 9n3 2006 Model Amp Wiring - Help
- Car Model: 2005 Polo 1.4 Trendline
- 1 Eyed Monkey
- Registered for: 16 years
- Membership No: 1280
Re: Polo 9n3 2006 Model Amp Wiring - Help
Theres a place on the left hand side you can use to run your power cable
Thanks 1 Eyed Monkey...any pictures perhaps?
Is this under the glove compartment side?
Under the wiper tray (passenger side) theres a grommet which leads to the cabin its difficult to get to, but then u also have to remove the cubby to pull the cable through. Its a real pain in the a$$
- Car Model: Golf MK5 2.0 TFSi
when i had my 9n3. i actually had no problem finding a place to push a 4 gauge cable through. from inside, i lifted the carpet, around where your left foot would be if you sitting in the car, i found a rubber grommet. poked a hole in it with a screw driver and pushed it in till i saw it on the other side.
