Hi all
Im fitting a aftermarket radio. I removed the factory Beta radio.
The after market radio one has one positive wire and the factory one has two.
Is the one with ignition only and other one straight from the battery? With is red and yellow.
Ill attache a pic with the wire diagram.
Fitting a aftermarket radio what positive wire to use
- Registered for: 10 years
Re: Fitting a aftermarket radio what positive wire to use
One is UB+ and one just +
Sent from my Alpha using Tapatalk
- Registered for: 7 years
- Car Model: Golf MK5 2.0 TFSi
use a test light or multi meter and see which only gives power when the ignition is on,
ive even seen people use a little 12v bulb as a test light
Cool, i have a multimeter. What setting should i put it on though?turbowheelchair wrote:use a test light or multi meter and see which only gives power when the ignition is on,
voltage. depending on your multimeter it could just say DCV for Direct current voltage.
Cool, figured that but just wanted to be sure.
