Hi,
I have just managed to retrofit a RC510 with MDI and the 9W7 bluetooth kit. All working 100%. I bought the Chinese knockoff Hex+Can Vag Com 11.11 just for this job. Does not make sense buying the licences version only to be used once.
The only problem I have now is that for some reason the steering wheel does not show in VCDS and I am unable to change the mute button to be used for the voice command of the 9W7. Might this be that I need a newer version of VCDS or might it be something else?
Does anyone know of someone that is quite good with these things in Cape Town? The VW dealers are quite useless, they were not able to assist me in the installation and mostly have a no can do attitude.
Polo 6R Bluemotion 2013 VCDS Steering Wheel
- Wheel Whore
- Car Model: Polo 6R Bluemotion
- Titleists
- Philosopher STIG
- Car Model: 2016 Golf R
- Membership No: 1520
Re: Polo 6R Bluemotion 2013 VCDS Steering Wheel
What option did you look at in the VCDS? Instruments or Central Electrics?
- Wheel Whore
It does not show up under installed. If I go under Confort/Conv, 16-Steering Wheel its unable to talk to a module at this address, the CAN times out. This is a brand new car with cruise control and the steering wheel works without any problems, volume mute and all the buttons work. So not sure whats going on. I am 100% certain its not a fault with the car itself. No fault code detected either.Titleists wrote:What option did you look at in the VCDS? Instruments or Central Electrics?
- Wheel Whore
- Sinbad
- Post Whore
- Car Make: Mercedes
- Membership No: 1152
Very latest VCDS?
- Wheel Whore
No, I think the lastest version is 11.11.4 if I am not mistaken. I have 11.11.0 .Sinbad wrote:Very latest VCDS?
This is what VCDS detects in a scan.
Tuesday,20,November,2012,12:51:20:37412
VCDS Version: Release 11.11.0
Data version: 20111111
Chassis Type: 6R0
Scan: 01 03 08 09 15 17 19 25 44 56 61
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J0000-CFWA) Labels: None
Part No SW: 03P 906 021 AH HW: 03P 907 425
Component: R3 1.2 DCM3.7 H09 3315
Revision: 12005001 Serial number:
Coding: 00114014032501080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TDI03103P906021AH 001004
ROD: EV_ECM12TDI03103P906021AH.rod
VCID: 6ED9BF1CB18C1AE
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0001
Revision: --------
Coding: 230224E3417300BBC42724E282D900921300
VCID: 82017BAC19148EE
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 39735C40B0428D6
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0353
Revision: BU050001 Serial number: 0456 220121101
Coding: 25B02BBF08E12400923809B0262B0CD05F80612F7E860441A00000000000
Shop #: WSC 124697 483 00190
VCID: 418334A0D892D56
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Coding: 58BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 5 - Part No: 1K8 951 171 A
Coding: 000000
Subsystem 6 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Coding: 020000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 58BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 58BC32
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag028 H10 0020
Revision: -------- Serial number: 003GX01CDRAT
Coding: 003238
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_VW25.rod
VCID: 4A91138CEDA416E
Crash sensor for side airbag; driver side:
Serial number: 3575HRB40671HA3K58G0
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB40551HA3K297U
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB400A4UFMUGGNY
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB404P1ADPCC9K0
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 K HW: 6R0 920 861 K
Component: KOMBI H03 0306
Serial number: 00000013112811
Coding: 140801
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01720
ROD: EV_DashBoardUDSJCIPQ25_VW25.rod
VCID: 3D7B4850AC6AB16
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6R0 907 530 E HW: 1K0 907 951
Component: J533 Gateway H38 0041
Revision: H38 Serial number: 280812F1003312
Coding: 2500C3
VCID: 356B50709C5A696
Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
Component: IMMO H03 0015
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
ROD: EV_ImmobUDSJCIPQ25_VW25.rod
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F676218EA06536
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 156 D HW: 5M0 035 156 D
Component: Radio 553 0555
Revision: R0553007 Serial number: VWZ5Z1M0738637
Coding: 0500040002
VCID: 2A51730C45E436E
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0041
Coding: 03031A59
VCID: F4ED2D7457A0B0E
Subsystem 1 - Part No SW: 6R0 915 181 E HW: 6R0 915 181 E
Component: J367-BDM H08 0181
End ---------------------------------------------------------------------
- Sinbad
- Post Whore
I had timeouts on certain modules when I was using an older VCDS. I'm willing to bet that's your problem.
- Wheel Whore
OK, That is what I think as well.
Does anyone know of someone in Cape Town that has a full licensed VCDS that might be able to help me?
- Wheel Whore
Ok, the Polo 6R I have does not contain a steering wheel module, but you can find the PPT option under Central Electronics.
