Vw citi golf fuel pump
Riazgaffley22
Registered for: 4 years 9 months
Post by Riazgaffley22 »
Hi pple, I need some advise. I bought a citi golf that was converted from fuel injection to carb and my issue is that there is currently a faset pump thats on the car, I need to replace it but not sure what electronic pump to use as I do not want to flood the carb and it will be in the same location that is close to the tank....
Please help TIA
Ashveer03
Re: Vw citi golf fuel pump
Post by Ashveer03 »
Get another facet pump?
Riazgaffley22
The issue is that the pump is too noisy with that tok tok sound and wanted to get something that would be silent
PapaJo
Registered for: 14 years
Car Make: VW's
Post by PapaJo »
So you don't have a place in the block for the std mechanical pump as the block is of a FI model.
Search for a low pressure fuel pump. I think Holley is making one and then get with it a fuel pressure regulator to set the fuel pressure to the carb around 3Psi. High pressure will create issues like needle and seat not sealing or bent or leaking carb.
Riazgaffley22
A friend of mine mentioned a huco pump not sure if it will work
PapaJo
Car Make: VW's
Post by PapaJo »
Riazgaffley22 wrote: Mon Jun 24, 2019 6:30 pm A friend of mine mentioned a huco pump not sure if it will work
Only way would be to try it or find someone that is using one to confirm if it will work.
Ashveer03
Post by Ashveer03 »
Try the facet pump with rubber mounts, it somewhat dampens the sound
Mav1424
Registered for: 4 years 8 months
Post by Mav1424 »
Hi everyone, I hope someone could please help me. I have a 2004 citi golf with a 2007 fuel injection motor, the car is carburetor instead of fuel injection though, so my problem is when I try and start my car it starts and revs up but when I take it for a drive then the car just cuts out like it's not getting fuel, I had the problem before and I just put a direct fuel connection from the fuel pump to the carburetor and the car drove but it was too heavy on fuel without the fuel return connected, so I took it into a mechanic and he connected everything the way it should be and still the car doesn't want to ride properly and now I don't know what the problem could be or what to do anymore, I have put a brand new return filter, new pipes, cleaned out the carb. I am also using a electric fuel pump instead of the mechanic fuel pump, so does anyone know what the problem could be or why the car drives with a straight connection but just dies as soon as you connect the return filter, please guys I need as much help as I can because I haven't been able to drive my car in a very long time, and what makes it worse is that when it was by the mechanic they stole my brand new bbs mag and Tyre.
