In white = fuel rail and 5 injectors
In red = the only plug to the fuel rail
In blue = fuel lines
Firstly this here is called hijacking, which usually doesn't warrant a response. Since I pity you, newb, I shall respond.Jojozmotorworx wrote:Hi guys I have a misfire problem on my caravelle 2.6i on idle it can rev up fully with a slight miss but once driven it misfires like crazy and has no power, I've done the cylinder head over I've skimmed the block I've checked the distributor,coil,leads and plugs what else could be wrong? Please assist and could someone plz tell me how to post my own question on this site as it is my first time using this thanks
Got a idling problem when you put the aircon on the kombi idle fineMike bond wrote:Got a idling problem when you put the aircon on the kombi idle fine
I have changed about every electical thing you can think of
EX-DOHCTOR wrote: I'd make sure I understand the differences between fish and engine components before attempting any modifications on my motor vehicle as a start.![]()
