Hi there,
I have a passat 2L tdi with a BKP code motor.
2 injectors went bad so I managed to source 2 injectors. The part number is 03G130073S (old units)
I found same part number but with a G at the end.
My question is, can I use that injector in the passat?
The car has been standing for a while now and I would like to fix it but finding injectors is a big problem. The price from the agents is just short of insane. R18073,00 per injector.
I would like any advice from anyone regarding this as I am now past desperate.
'06 Passat B6 2L Tdi Injectors
- Neuk
- Treasurer
- Membership No: 806
Re: '06 Passat B6 2L Tdi Injectors
Where are you based?
Not too sure on the 2L tdi engines, but on the 1.9tdis the last alphabet makes a big difference. Generally they cannot be mixed up.
Example AL is a 550cc & AG is a 425CC.
If u mix those 2, u gonna have problems.
Could be the same in your case. Might as well find the correct part number or replace all 4 with the same number - car will have to be tuned to suit the injectors after that.
- Registered for: 2 months
I am based in Durban (Umdloti Beach) to be exact
